Hello,
I have Arduino Due,and Want to run my Code in setup loop but it fails.
My intention is to run the code only once.But the purpose fails in the setup loop.
I want to open "Spotlight Search" on my mac by pressing cmd+space.
I fail to execute this task in setup() loop and but in loop() it works and never stops.
I tried to run an infinite loop after my code in loop so it executes one But it doesn't work.
All the cases gets compiled but only one case actually works and that is the code in loop.
#include "Keyboard.h"
#include "Mouse.h"
char ctrlKey = KEY_LEFT_GUI;
int i=1;
Keyboard.begin();
// Keyboard.press(KEY_LEFT_GUI);
// Keyboard.press(32);
// delay(100); //deosnt work
// Keyboard.releaseAll();
//Start(); //doesnt work
Keyboard.press(ctrlKey);
Keyboard.press(32);
delay(100);
Keyboard.print("Terminal"); //works but doesnt stops
while(true)
//doesnt work
/*void Start()
Keyboard.press(32);
delay(100);
AIM: To make code cmd+space execute only once.
That boggles my mind.
Anything in setup() should run exactly once.
Anything in loop() should run repeatedly after setup() has run.
while(true)
//doesnt work
should cause loop() to get stuck and never run again.
Please change something (say, "Terminal" to "Terminal 2") to verify that you actually compiled and loaded this code.
Also, in the future,
To post code and/or error messages:
- Use CTRL-T in the Arduino IDE to autoformat your code.
- Paste the autoformatted code between code tags (the </> button)
so that we can easily see and deal with your code.
- Paste the complete error message between code tags (the </> button)
so that we can easily see and deal with your messages.
Before posting again, you should read the three locked topics at the top of the Programming Questions forum, and any links to which these posts point.
Good Luck!
The autoformatting (step 1) is missing, making the code a little harder to read.
Because the while loop doesn't do anything, it's probably optimized away by the compiler. Put this statement:
i++;
in the while statement block and see if it goes into an infinite loop.
vaj4088:
while(true)
//doesnt work
1) Use CTRL-T in the Arduino IDE to autoformat your code.
2) Paste the autoformatted code between code tags (the </> button)
3) Paste the complete error message between code tags (the </> button)
Good Luck!
Sir I tried But it keeps on looping
It completely ignores the setup() code
Hi vidit,
What happens if you put a println in your setup code? Do you see that?
Pat.
Hello Sir,
The code doesn't get executed in Setup() but gets executed in Loop().
#include "Mouse.h"
int i = 1;
Keyboard.begin();
Keyboard.println("HEllO");
// Keyboard.press(ctrlKey);
//eyboard.releaseAll();
//while (true)
// Keyboard.print("Terminal");
//delay(100);
//Keyboard.write(KEY_RETURN);
void Start()
Keyboard.press(32);
delay(100);
Hi vidit,
Can you supply 2 files? One that works and one that doesn't? It is difficult to tell which code you posted with the comments.
I'd like to recreate the exact conditions.
Also, Start isn't called. I assume it is not part of this problem.
Pat
Also, try this from the Arduino tutorial and let me know what happens:
//start keyboard communication
Keyboard.begin();
//send a keystroke
Keyboard.print("Hello!");
//end keyboard communication
Keyboard.end();
//do nothing
econjack:
Nonsense. The compiler cannot change "stay here forever" to "ignore this".
The USB enumeration between the PC and Due could take a couple of seconds, thus, if you add a delay after the keyboard initialization, your code should work.
I just tried the following example and it worked OK.
Keyboard.begin();
delay(2000);
Keyboard.println("Hello!");
Regards,
-p
Palliser:
Keyboard.begin();
delay(2000);
Regards,
-p
Thank you so much for you help.
It worked.
