Setup for pumping/transporting high viscosity liquid (mud)
I am about to embark a project where I need to pump high viscosity liquid, like thick mud, 2-3 meters up from a container and let it very slowly run back over a sharply tilted wall.
It should be a very slow pace. The motor noise has to be very low.
I need to be able to adjust the speed from either a (simple) control panel or serially from a computer. This is the easy part.
I figure I either have to use something like a slurry pump or build something with "buckets" on a belt.
Does it sound odd? It is for an art project.
What motors or pumps could I use and what is the best way to interface them with the arduino?
Any help that can make me proceed is really appreciated.
Cheers
Slow turning hose pump with a very thick hose. Or more elaborate a pump with 2 interlocking rotors like a gear pump.
Archimedes screw will work perfectly for this project!
What is the need to interface them with an Arduino?
Thats a great idea (Archimedes screw)! I should be able to prototype that quite easily. Either 3d print something or just a hose around a pipe. I am planning doing some smaller prototypes first. 1x1 meter or even smaller.
I need to be able to adjust the speed of the flow. I will trigger/modulate electronic sounds with sensors detecting the speed and thickness of the mud when it passes certain areas on the wall. I will need to be able to adjust the speed of the motor depending on how the sounds act. This may need to happen dynamically, automated.
Concrete, very much like thick mud, is pumped with positive displacement piston pumps. Sometimes peristaltic pumps are used, too.
Will you ever need to clean the machine? If so, your plan?
Honestly I have not considered this yet. Maybe just by running hot water through it. An enclosed screw may pose a problem.
I will try to make av working mockup next few days using a vacuum cleaner tube and other trash.
