Setup function not executing
I am sure I am missing something extremely simple here. But why doesn't this code print "hi"?
When someFunc() is placed in the loop it works, but not in setup.
  someFunc();
  //someFunc();
void someFunc()
  Serial.println("hi");
Does it print if you do this?
Which Arduino board are you using ?
hmm, strangely no that doesn't print either...
I am using MKR Zero
Then the problem is unrelated to "External function scope"
Try this
  while (!Serial);
  someFunc();
void someFunc()
what is your serial monitor bit rate?
That did it. Thanks!
I also found that adding a delay(1000); after the Serial.begin worked. So it must be firing before the serial has initialized. I thought it was some weird scope issue.
