Setup pins
Can somebody help me out.
I made a
void Led(int X, int state){
DigitalWrite(Y, 0 or 1);
Now i need a Number on Y.
If X=1,37,73,109,145,181 Y=1
If X=2,38,74,110,146,182 Y=2
3,.,.,. Y=3
UNTIL Y=36.
Ik an anyone help me out.
Do your own homework.
This is probably a good place to start.
Y=X % 36;
It looks like you need to check the syntax for the if command in C++ and how to spell other commands correctly too
Maybe you mean
if (X == 1 || X ==37 || X == 73 || X == 109 || X == 145 || X == 181)
  Y = 1;
I note, however, that the values being checked are in a series with a fixed interval and only vary in their starting value for each value of Y. A perfect job for a computer program
When is our assignment due ?
Lol its not homework.
I am not in school sinds 30 years ago.
I, am building a 6x6x6 ledcube.
At this point i have for void Led 6x a if statement.
But i want to make it shorter.
void Led(int Y, int state) ;
If (Y >0 & & Y <37){
digitalWrite(Y, state) ;}
else if (Y >36 & & Y <73){
digitalWrite(Y - 36,state) ;}
And so on.
But i need space
Did you note the suggestion to try the modulo operator ?
Well i did my home work.
I noticed that arduino only use whole integers in int so 1,9=1 and 2.1=2
So this way it would work.
Y= Y- (Y-1)/36+1) 36
37=37 - (1
36)=1
38=38- (136)=2
73=73-(2
36)=1
But Now i don, 't know what is the right way to write the formula
Y-(Y-1)/36+1)*36??
What have you tried ?
Jeroentje2212:
37=37 - (1
36)=1
38=38- (136)=2
73=73-(2
36)=1
Y-(Y-1)/36+1)*36??
Whoa, weird echo in here.
I got some thing else.
]Y- (36* (Y+35)/36 - 1)
If Y = 36
36=36 - (36*(36+35)/36-1)
36=36 - (36*(integer 0)
36=36 - (36*0)
=36
37=37 - (36*(36+35)/36-1
37=37 - (36*(integer 1)
37=37 -(36*1)
=1
But Now how to formulate???
Jeroentje2212:
If Y = 36
36=36 - (36*0)
=36
37=37 -(36*1)
=1
Did you note the suggestion to try the modulo operator ? (Reply #2)
Yes i did but i do not understand de modulo operator because i, am noob.
Started arduino and code writing for Just a month now
Out of interest when did you start using mathematics ?
Jeroentje2212:
The modulo or remainder operator (represented by %) returns the remainder of any integer division.
e.g. 37 % 36 returns 1, 41 % 36 returns 5, 14 % 36 returns 14.
Does this sound like what you require?
See the Arduino % reference page here:-
https://www.arduino.cc/reference/en/language/structure/arithmetic-operators/remainder/
Ian
I think it is but do not know how to use it
I need 2 things.
First one is
1 to 36== 1to 36
37to72==1 to 36
73 to 108==1 to 36.
DigitalWrite(formule 73, High=1, HIGH)
OK so i can use (int %36)
The second one is.
1 to 6= +0
7 to 12= +2
13 to 18=+4
19to 24=+6
DigitalWrite(formule 7=9)
Digitalwrite(formule 13=17)
Jeroentje2212:
1 to 36== 1to 36
37to72==1 to 36
73 to 108==1 to 36.
Y modulo 36 would not directly work, because that would give you 0 through 35.
Offsetting the input by 1, so you have 0 through 35, will allow you to do the modulo arithmetic, then adding 1 to the result will give you the desired answer.
( ( Y - 1 ) % 36 + 1 )
you can also do it as integer math without the modulo operator:
(y - 1) - ( (y - 1) / 36 * 36 ) + 1
or simplifying a bit:
y - ( (y - 1) / 36 * 36 )
The second one is.
1 to 6= +0
7 to 12= +2
13 to 18=+4
19to 24=+6
Easier to offset the input by 1 on this problem also, so you have:
0 to 5 = +0
6 to 11 = +2
12 to 17 = +4
18 to 23 = +6
Every 6th number you are increasing by 2, so divine by 6, ignore any remainder, and multiply by 2 to get the desired result.
Jeroentje2212:
I need 2 things.
First one is
1 to 36== 1to 36
37to72==1 to 36
73 to 108==1 to 36.
The second one is.
1 to 6= +0
7 to 12= +2
13 to 18=+4
19to 24=+6
For the first part just use the modulo of your value-1 divided by 36 and add 1 i.e.
result = (value - 1) % 36 + 1
For the second part take your value and add the value -1 divided by six then multiplied by two i.e.
result = value + (((value-1)/6)*2)
This works because integer division will return 0 if value -1 is in the range 0 to 5, 1 if it is in the range 6 to 11, 2 if it is in the range 12 to 17 and 3 if it is in the range 18 to 23.
Ian
///for pins 1 to 6 to (1 to 6) and 7 to 12 to (9 to 14)
void Col(int A, int state) ;
shift.writeBit(A +(((A - 1)/6)*2), state);
void Led(int L, int state)
/// for 1 - 36 to (1 - 36) and 37 - 72 to (1 - 36)
Col((L) %36 +1, state) ;
Layer((L+35)/36); //1-36= layer1 37-72=2
//Layer is also Functions Layer1 on 2-6 off and otherwise.
Like this :wink:
I'd probably have gone for:
Y = X % 36;
if(Y==0) Y=36;
Formula Y+(((Y - 1)/6)*2 is wrong.
36 becomes 47 and need to be 46.
