Seven segment display 0-999 up down counter
I am building a up down counter using push buttons counting from 0-999 normally my program is working but have to make some modifications like
From 40-100 it will count with a 5 increments i.e 40-45-50-55 till 100
And from 100-999 with a 10 digit increments like 100-110-120-130 and so on
Could you take a few moments to Learn How To Use The Forum.
Posting tips.
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • How to insert an image into your post. ( Thanks Robin2 )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
Show us a good schematic of your circuit.
Show us a good image of your wiring.
Give links to components.
Posting images:
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu.
[code]Paste your sketch here[/code]
