excuse me I want to ask,
I'm working on a bank queue system project based on Arduino Mega 2560, the components used are
an ultrasonic sensor as a queue number paper printer, seven-segment as a display viewer,
df player and speaker as service caller,
long story short, after the program, is put together then the seven-segment flashes...
the question is, how to prevent the seven-segment flicker from happening when it is combined with other programs? here is the program
#include "PString.h"
#include "Adafruit_Thermal.h"
#include "SoftwareSerial.h"
#define TX_PIN 15 // Pin 11 Arduino ke RX Printer
#define RX_PIN 14 // Pin 10 Arduino ke TX Printe
SoftwareSerial mySerial(RX_PIN, TX_PIN);
Adafruit_Thermal printer(&mySerial);
int hitung_teller = 0;
int hitung_CS = 0;
int trig_teller = 13; // membuat varibel trig di set ke-pin 11
int echo_teller = 44; // membuat variabel echo di set ke-pin 12
long durasi_teller, jarak_teller; // membuat variabel durasi dan jarak
int trig_CS = 45;
int echo_CS = 46;
long durasi_CS, jarak_CS;
const int buttonPin = A4;
long lastDebounceTime = 0;
long debounceDelay = 50;
int buttonState = 0;
int lastButtonState = LOW;
//=================seven segmen=====================//
long lastButton = 0;
long delayAntiBouncing = 50;
byte panggilTeller, panggilCS;
byte seven_seg_digits[10][7] {
{0, 0, 0, 0, 0, 0, 1},
{1, 0, 0, 1, 1, 1, 1},
{0, 0, 1, 0, 0, 1, 0},
{0, 0, 0, 0, 1, 1, 0},
{1, 0, 0, 1, 1, 0, 0},
{0, 1, 0, 0, 1, 0, 0},
{0, 1, 0, 0, 0, 0, 0},
{0, 0, 0, 1, 1, 1, 1},
{0, 0, 0, 0, 0, 0, 0},
{0, 0, 0, 0, 1, 0, 0},
//================SPEAKER====================//
#include <miniMP3.h>
#define belas 12 //belas.mp3
#define puluh 13 //puluh.mp3
#define seratus 14 //seratus.mp3
#define ratus 15 //ratus.mp3
#define seribu 16 //seribu.mp3
#define ribu 17 //ribu.mp3
#define nomorantrian 170 //nomor antrian.mp3
#define teller 190
#define customers 191
uint32_t NomorPanggilTeller = 0;
uint16_t NomorPanggilCS2 = 0;
//===================SETUP===============//
void setup(){
pinMode(trig_teller, OUTPUT); // set pin trig menjadi OUTPUT
pinMode(echo_teller, INPUT); // set pin echo menjadi INPUT
pinMode(trig_CS, OUTPUT);
pinMode(echo_CS, INPUT);
pinMode(buttonPin, INPUT_PULLUP);
mySerial.begin(9600); // digunakan untuk komunikasi Serial dengan komputer
printer.begin();
mp3_set_serial (Serial1, 17);
mp3_set_volume(30);
for(char i=2; i<13; i++){
pinMode(i,OUTPUT);
pinMode(A0,INPUT); //buttonTeller
pinMode(A2,INPUT); //buttonCS
pinMode(A4,INPUT); //buttonRiset
digitalWrite(A0,HIGH);
digitalWrite(A2,HIGH);
digitalWrite(A4,HIGH);
//====================program utama================//
void loop(){
digitalWrite(trig_teller, LOW);
delayMicroseconds(8);
digitalWrite(trig_teller, HIGH);
durasi_teller= pulseIn(echo_teller, HIGH); // menerima suara ultrasonic
digitalWrite(trig_CS, LOW);
digitalWrite(trig_CS, HIGH);
durasi_CS= pulseIn(echo_CS, HIGH); // menerima suara ultrasonic
jarak_teller= (durasi_teller/2) / 29.1; // mengubah durasi menjadi jarak (cm)
jarak_CS = (durasi_CS/2) / 29.1; // mengubah durasi menjadi jarak (cm)
Serial.println(jarak_teller); // menampilkan jarak pada Serial Monitor
Serial.println(jarak_CS); // menampilkan jarak pada Serial Monitor
if (jarak_teller <= 6) {
printer.wake();
printer.setDefault();
hitung_teller += 1;
char buffer[40];
PString str(buffer, sizeof(buffer));
if (hitung_teller < 10)
str.print(0);
if (hitung_teller > 10)
str.print(1);
str.print(hitung_teller);
printer.boldOn();
printer.setSize('L');
printer.println("Nomor Antrian");
printer.justify('C');
printer.setSize('M');
printer.println(str);
printer.println("Teller");
printer.feed(3);
printer.sleep();
else {
printer.sleep();
if (jarak_CS < 6) {
printer.wake();
hitung_CS += 1;
char buffer[40];
if (hitung_CS < 10)
str.print(0);
if (hitung_CS > 10)
str.print(1);
str.print(hitung_CS);
printer.boldOn();
printer.println("Customer service");
printer.feed(3);
printer.sleep();
else {
printer.sleep();
if (!(digitalRead(buttonPin))) {
printer.wake();
hitung_teller = 0;
hitung_CS = 0;
char buffer[40];
printer.println(F("Printer direset"));
hitung_teller = 0;
hitung_CS = 0;
printer.feed(3);
printer.sleep();
else {
printer.sleep();
tampilSkor();
tombol();
void tampilSkor(){
digitalWrite(10,LOW); digitalWrite(9,HIGH);
digitalWrite(11,HIGH); digitalWrite(12,HIGH);
sevenSegWrite(panggilTeller / 10);
delay(5);
digitalWrite(10,HIGH); digitalWrite(9,LOW);
sevenSegWrite(panggilTeller % 10);
delay(5);
digitalWrite(10,HIGH); digitalWrite(9,HIGH);
digitalWrite(11,LOW); digitalWrite(12,HIGH);
sevenSegWrite(panggilCS/ 10);
delay(5);
digitalWrite(11,HIGH); digitalWrite(12,LOW);
sevenSegWrite(panggilCS % 10);
delay(5);
void sevenSegWrite(byte segment){
byte pin = 2;
for (byte segCount = 0; segCount < 7; ++segCount) {
digitalWrite(pin, seven_seg_digits[segment][segCount]);
++pin;
void tombol(){
//-----------------tombol Teller =================
if(digitalRead(A0)==0){
if(hitung_teller > panggilTeller){
if ((millis() - lastButton) > delayAntiBouncing ){
panggilTeller++;
mp3_play(nomorantrian);
suaraBilangan(panggilTeller);
mp3_play(teller);
if(panggilTeller>=100)panggilTeller = 0;
lastButton = millis();
//-----------------tombol CS ====================
if(digitalRead(A2)==0){
if (hitung_CS > panggilCS){
if ((millis() - lastButton) > delayAntiBouncing){
panggilCS++;
suaraBilangan(panggilCS);
mp3_play(customers);
if(panggilCS>=100)panggilCS= 0;
//---------------tombol RESET
if(digitalRead(A4)==0){
panggilTeller=0;
panggilCS=0;
void suaraBilangan(uint32_t Bilangan)
if (Bilangan < 12)
mp3_play(Bilangan);
else if (Bilangan < 20)
suaraBelasan(Bilangan);
else if (Bilangan < 100)
suaraPuluhan(Bilangan);
void suaraBelasan(uint8_t Bilangan)
mp3_play(Bilangan - 10);
mp3_play(belas);
void suaraPuluhan(uint8_t Bilangan)
uint8_t puluhan = Bilangan / 10;
mp3_play(puluhan);
mp3_play(puluh);
uint8_t satuan = Bilangan % 10;
if (satuan)
suaraBilangan(satuan);
