Seven Segment Flickering
Hi guys, I am using arduino nano to connect the seven segment with TPIC6C596 shift register. There are four shift registers and four seperate seven segments used. When I upload the code in the arduino, the seven segments are displaying good. But while displaying the seven segment for example 1.234, the other segment LEDs starts flickering. I found that this is due to the shift registers i.e., the values are shifting.
Can anyone tell me why my seven segments starts flickering?
Hereby I upload my code for your reference.
  int DS_pin = 7;   // Data pin of 74hc595 connected to the 11th pin of Arduino Uno(10 for TPIC6C596)
  int STCP_pin = 6; // Latch pin of 74hc595 connected to the 12th pin of Arduino Uno(9 for TPIC6C596)
  int SHCP_pin = 5 ; // Clock pin of 74hc595 connected to the 8th pin of Arduino Uno(8 for TPIC6C596)
  int gpin = 4;
  int samplse = 0;   // the first sensor value
  int samplse1 = 0;  // the second sensor value
  float sensorvalue4;// Variable to store the final values in 7 segment display
  /* values that are assigned to the name of the macros */
//  #define x1 0.564662421366142
//  #define x2 1.22135167695223
  /* 7 segment common anode values ranging from 0 to 9 */
  int dec_digits [11] = {
 B00111111, //0
  B00000110, //1
  B01011011, //2
  B01001111, //3
  B01100110, //4
  B01101101, //5
  B01111101, //6
  B00000111, //7
  B01111111, //8
  B01101111, //9
/* setup initializes serial and the pin settings */
  Serial.begin(9600);          // 9600 Baud Rate
  Serial.println(" Metal Width Detector\n ");
  //set pins to output
  pinMode(DS_pin, OUTPUT);     // Setting Data Pin as an OUTPUT
  pinMode(STCP_pin, OUTPUT);   // Setting Latch Pin as an OUTPUT
  pinMode(SHCP_pin, OUTPUT);   // Setting Clock Pin as an OUTPUT
  pinMode(gpin, OUTPUT);   // Setting gPin as an OUTPUT
  digitalWrite(SHCP_pin, LOW); // Write Pin as LOW
  digitalWrite(DS_pin, LOW);   // Write Pin as LOW
  digitalWrite(STCP_pin, LOW); // Write Pin as LOW
  digitalWrite(gpin, LOW); // Write Pin as LOW
/* loop checks the sensor state and will send serial after calibration */
  // read the first sensor
  int samplse = analogRead(6);
  // read the second sensor
  int samplse1 = analogRead(7);
  /* map(value, fromLow, fromHigh, toLow, toHigh)
   * map - maps a number from one range to another.
   * value - the number to map.
   * fromLow - the lower bound of the value’s current range.
   * fromHigh - the upper bound of the value’s current range.
   * toLow - the lower bound of the value’s target range.
   * toHigh - the upper bound of the value’s target range.
  float sensorvalue = (map(samplse, 0, 1023, -3500, 3500) / 100.0);     // Map an analog value to 10 bits(0 to 1023) and the target range
  float sensorvalue1 = (map(samplse1, 1023, 0, -3500, 3500) / 100.0);    // Map an analog value to 10 bits(0 to 1023) and the target range
  // apply the calibration to both the sensor reading
  //float sensorvalue = (x1 - pow(val, x2));  // Calibration value of first sensor
  //float sensorvalue1 = (x1 + pow(val1, x2));// Calibration value of second sensor
  /* print the sensor values in the serial monitor, if necessary */
// float sensorvalue=sensorvalue01;
//  float sensorvalue1=sensorvalue02;
  Serial.print("sensorvalue:");
  Serial.println(sensorvalue, 3);
  Serial.print("sensorvalue1:");
  Serial.println(sensorvalue1, 3);
  /* Subtracting both the sensor values and display in the 7 segment using shift register */
  sensorvalue4 = (sensorvalue - (sensorvalue1))-0.77;
  if(sensorvalue4<0)
    sensorvalue4 = sensorvalue4*(-1);
    Serial.println(sensorvalue4, 4);
     sensorvalue4 = sensorvalue4*(1);
  // calling function
  updateDisplay();
void updateDisplay()
  /* To print the values in the serial monitor, if necessary */
  Serial.print("sensorvalue4:");
  char buf[10]; // A variable that contains char values
  dtostrf - This function converts the float values to the char.
  dtostrf(floatvar, StringLengthIncDecimalPoint, numVarsAfterDecimal, charbuf);
  floatvar - float variable
  StringLengthIncDecimalPoint - This is the length of the string that will be created
  numVarsAfterDecimal - The number of digits after the decimal point to print
  charbuf - the array to store the results
  dtostrf(sensorvalue4, 5, 3, buf);
  // Writing LOW on the STCP pin allows us to send data to the IC
  /* for loop execution */
   for (int i = 0; i <= 4; i++)
    if (buf[i] != '.')
      if (buf[i + 1] == '.')
        /* shiftOut(dataPin, clockPin, bitOrder, value)
         * shiftOut - Shifts out a byte of data one bit at a time.
         * dataPin - the pin on which to output each bit. Allowed data types: int.
         * clockPin - the pin to toggle once the dataPin has been set to the correct value. Allowed data types: int.
         * bitOrder - which order to shift out the bits; either MSBFIRST or LSBFIRST.
         * value - the data to shift out. Allowed data types: byte.
         * converting the resultant char value to a decimal value.
         * adding the decimal point wherever we want in the seven segment display
        shiftOut(DS_pin, SHCP_pin, MSBFIRST, dec_digits[(buf[i] - 0x30)] + 0x80);
          digitalWrite(STCP_pin, HIGH);
        shiftOut(DS_pin, SHCP_pin, MSBFIRST, dec_digits[(buf[i] - 0x30)]);
  // Writing HIGH on the STCP pin, no longer needs to listen for information
  // waits for a second
  delay(4000);
You should only be writing to the display if there is a change in the value to be displayed.
The values will change according to the sensor readings. If there are no values changing also, the shift register starts shifting the same values and the it flickers automatically.
        //  digitalWrite(STCP_pin, LOW); delete this line
        //  digitalWrite(STCP_pin, HIGH); delete this line
Delete the lines indicated above.
Is that a question or your answer ? Yes because you are constantly updating the registers flickering occurs.
The shift registers have output buffers, they can be updated as often as the OP wishes without causing flickering. The flickering is due to those output buffers being updated before the data for all 4 digits has been shifted out.
If there is flickering during this period then, since you are not interrupts, there must be another problem. Post the schematic.
Metal Width Detector.pdf (168.9 KB)
ok. I will update you after changing that. Thanks
I have a strong feeling of déjà vu here.
The schematic does not include the critical components here.
It must show the TPIC6C596 and the seven segment display elements and all interconnections.
winehq
Don't forget to add a 0.1uF ceramic capacitor near the Vcc pin of each shift register.
okay
Thanks alot my dear friend. thanks for your help. It worked
These don't match the schematic.
Yes
Thanks for your help too!
I found the solution...
Hi friend, I have an issue with the HG-C 1100 measurement sensor. This sensor is used to measure the width of any material.
For this also the same programming works. How can i calibrate the sensor and get it.
I am not familiar with that sensor. Can you post a link to the data sheet for it? I looked at the schematic you attached to post #8 but I could not understand that. It showed an Arduino nano V3 but the other parts are not labelled.
HG-C_Series.pdf (3.0 MB)
