Seven segment interfacing, function not declared in scope error
byte a,pos,count,convert,bit_value,segment_pins[]={2,3,4,5,10,11,12,13};
  for (a=0;a<=7;a++)
 pinMode(segment_pins[a],OUTPUT);
count=0;
  up_count();
void up_count()
  convert=bintobcd(count);  //the error message appears in this line
  pos=7
  for(a=0;a<=7;a++)
    bit_value=bitRead(convert,pos);
    digitalWrite(segment_pins[a],bitvalue);
    pos=pos-1;
  delay(300);
  count=count+1;
  if(count==100)
    count=0;
  }           //up count loop ends here
  byte bintobcd(byte recv)
    byte q,r; //quotient,remainder
    q=recv/10;
    r=recv%10;
    q<<4;    //MSB shifted 4 spaces to left
    q|r;     //OR operator
    return q;
error message:
‘bintobcd’ was not declared in this scope
This code is designed for a typical counter for counting from 0 to 99. However there is an error message for not declaring bintobcd. What change must I make in the top-most line for this program to work?
Edit: Autoformatting has removed the previous error. The new error message says:
‘bintobcd’ cannot be used as a function
What might be the problem here?
Your bintobcd() function is in the wrong place. check the {}
(indent the code and you’ll see it)
    q|r;     //OR operator
