'sever' does not name a type error
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
//static IP config
IPAddress staticIP(192, 168, 1, 1);              //Node static IP
IPAddress gateway(192, 168, 0, 174);             //IP on router
IPAddress subnet(255, 255, 255, 0);              //subnet mask
IPAddress dns(8,8,8,8);                          //DNS
const char* deviceName = "Blindz Controller";
// WiFi settings
const char* ssid = "SSID Here";             //network ID here
const char* password = "Passwordhere";             //network password here
ESP8266WebServer server(80);                     //Server port 80
//int motor_mode = 0;
// motor settings
#define MOTOR_PIN1    4                         //pin 1 of Blindz motor (D2)
#define MOTOR_PIN2    5                         //pin 2 of Blindz motor (D1)
#define MOTOR_SPEED_DOWN   800                  //speed going down (0-1023)
#define MOTOR_SPEED_UP    1023                  //speed for going back up going up requires a higher speed
int blindz_mode = 0; // set blindz drive mode (0 = stop)
// initialize
  Serial.begin(115200);                        //Buad rate 115200 for debugging/serial monitor
  Serial.println("Blindz Server");
  pinMode(MOTOR_PIN1, OUTPUT);
  pinMode(MOTOR_PIN2, OUTPUT);
//  blinds_mode();  //stop blinds
  WiFi.begin(ssid, password);                 //Connects to router
  Serial.println("");
  WiFi.disconnect();                          //prevents connecting to wifi on previous config
  WiFi.hostname(deviceName);
  WiFi.config(staticIP, subnet, gateway, dns);
  WiFi.mode(WIFI_STA);                       //WiFi station mode
  while (WiFi.status() != WL_CONNECTED){     //wait for connection
      Serial.print(".");
  Serial.println(" ");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());            //IP assigned to node
  Serial.print("Blindz are live");
  // setup web server to handle specific HTTP requests
  server.on("/", HTTP_GET, handle_OnConnect);
  server.on("/Up", HTTP_GET, handle_up);
  server.on("/Down", HTTP_GET, handle_down);
  server.on("/Stop", HTTP_GET, handle_stop);
  server.on("/Open", HTTP_GET, handle_open);
  server.on("/Close", HTTP_GET, handle_close);
  server.onNotFound(handle_NotFound);
  //start server
  server.begin();
  Serial.println("NodeMCU web server started.");
// handle HTTP requests and control blindz
  server.handleClient();
  blindz_control();
// HTTP request: on connect
void handle_OnConnect() {
  blindz_mode = 0;
  Serial.println("Client connected");
  server.send(200, "text/html", SendHTML());
// HTTP request: stop blinds
void handle_stop() {
  blindz_mode = 0;
  Serial.println("Stopped");
// HTTP request: blinds go up
void handle_up() {
  blindz_mode = 1;
  Serial.println("Going Up...");
// HTTP request: blinds go down
void handle_down() {
  blindz_mode = 2;
  Serial.println("Going Down...");
// HTTP request: blinds fully close
void handle_close() {
  blindz_mode = 3;
  Serial.println("Time for Bed");
// HTTP request: blinds fully open
void handle_open() {
  blindz_mode = 4;
  Serial.println("Rise and Shine");
// HTTP request: other
void handle_NotFound() {
  blindz_mode = 0;
  Serial.println("Page error");
  server.send(404, "text/plain", "Not found");
// control blinds movement
void blindz_control() {
  switch (blindz_mode) {
    case 0: // stop blindz
      digitalWrite(MOTOR_PIN1, LOW);
      digitalWrite(MOTOR_PIN2, LOW);
    case 1: // go up
      analogWrite(MOTOR_PIN1, MOTOR_SPEED_UP);
    case 2: // go down
      analogWrite(MOTOR_PIN2, MOTOR_SPEED_DOWN);
   //add case for fully open and fully close
// output HTML web page for user
String SendHTML() {
  String html = "<!DOCTYPE html>\n";
  html += "<html>\n";
  html += "<head>\n";
  html += "<title>Das Blindz</title>\n";
  html += "<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n";
  html += "</head>\n";
  html += "<body>\n";
  html += "<div align=\"center\">\n";
  html += "<h1>Das Blindz</h1>\n";
  html += "
\n";
  html += "<form method=\"GET\">\n";
  html += "<input type=\"button\" value=\"Up\" onclick=\"window.location.href='/Up'\">\n";
  html += "
\n";
  html += "<input type=\"button\" value=\"Down\" onclick=\"window.location.href='/Down'\">\n";
  html += "
\n";
  html += "<input type=\"button\" value=\"Stop\" onclick=\"window.location.href='/Stop'\">\n";
  html += "<input type=\"button\" value=\"Open\" onclick=\"window.location.href='/Open'\">\n";
  html += "<input type=\"button\" value=\"Close\" onclick=\"window.location.href='/Close'\">\n";
  html += "</form>\n";
  html += "</div>\n";
  html += "</body>\n";
  html += "</html>\n";
  return html;
//start server
server.begin();
None of this code is in a function
For future reference, if you're going to quote error messages, please do so accurately, using cut-and-paste.
Duplicate topic deleted
@NeedHelpWithThis - in future do not start a second topic on the same subject
