Several errors compiling
Hello to all.
Im building this:
Usig this code:
And getting these errors:
Arduino:1.8.13 (Windows 10), Tarjeta:"Arduino Uno"
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp: In member function 'void Adafruit_CircuitPlayground::playTone(uint16_t, uint16_t, bool)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:215:3: error: 'PLLFRQ' was not declared in this scope
PLLFRQ = (PLLFRQ & 0xCF) | 0x30; // Route PLL to async clk
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:215:3: note: suggested alternative: 'PCIFR'
PCIFR
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:3: error: 'TCCR4A' was not declared in this scope
TCCR4A = _BV(COM4A0) | _BV(PWM4A); // Clear on match, PWMA on
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:3: note: suggested alternative: 'TCCR0A'
TCCR0A
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\pgmspace.h:90,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28,
from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:20,
from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:30:
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:17: error: 'COM4A0' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:17: note: suggested alternative: 'COM0A0'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:31: error: 'PWM4A' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:31: note: suggested alternative: 'PWM'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:3: error: 'TCCR4B' was not declared in this scope
TCCR4B = _BV(PWM4X) | scalebits; // PWM invert
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:3: note: suggested alternative: 'TCCR0B'
TCCR0B
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:17: error: 'PWM4X' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:17: note: suggested alternative: 'PWM'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:218:3: error: 'TCCR4D' was not declared in this scope
TCCR4D = 0; // Fast PWM mode
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:218:3: note: suggested alternative: 'TCCR0A'
TCCR0A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:219:3: error: 'TCCR4E' was not declared in this scope
TCCR4E = 0; // Not enhanced mode
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:219:3: note: suggested alternative: 'TCCR0A'
TCCR0A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:220:3: error: 'DT4' was not declared in this scope
DT4 = 0; // No dead time
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:220:3: note: suggested alternative: 'DD4'
DD4
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:226:3: error: 'TC4H' was not declared in this scope
TC4H = hi1;
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:226:3: note: suggested alternative: 'PC4'
TC4H = hi1;
PC4
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:227:3: error: 'OCR4C' was not declared in this scope
OCR4C = lo1; // TOP
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:227:3: note: suggested alternative: 'OCR2A'
OCR4C = lo1; // TOP
OCR2A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:229:3: error: 'OCR4A' was not declared in this scope
OCR4A = lo2; // 50% duty
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:229:3: note: suggested alternative: 'OCR2A'
OCR2A
exit status 1
Any one could help?
Thanks
Looks to me like you’re compiling for the wrong processor.
TheMemberFormerlyKnownAsAWOL:
Looks to me like you're compiling for the wrong processor.
Ive just testet a sketch and works fine :frowning:
Well It looks like Im getting these errors when trying to use
Adafruit_SSD1306 / or Adafruit-GFX-Library
anibaluru:
But, a different sketch. Probably one with no processor register references.
Im using ATmega328p CH340G and select Arduino Uno in Boards->
Did you install the required libraries?
 * Required library
 *    TimerOne https://playground.arduino.cc/Code/Timer1
 *    Encoder https://www.pjrc.com/teensy/td_libs_Encoder.html
 *    MIDI https://github.com/FortySevenEffects/arduino_midi_library
 *    Adafruit SSD1306 https://github.com/adafruit/Adafruit_SSD1306
aarg:
 * Required library
*    Encoder Encoder Library, for Measuring Quadarature Encoded Position or Rotation Signals
*    MIDI GitHub - FortySevenEffects/arduino_midi_library: MIDI for Arduino
*    Adafruit SSD1306 GitHub - adafruit/Adafruit_SSD1306: Arduino library for SSD1306 monochrome 128x64 and 128x32 OLEDs
Yes, right from those URLs
The UNO has no timer 4. So there can't be any 'TCCR4A' for example... did you change anything in the sketch? Those errors are coming from a "CircuitPlayground" library that is (hopefully) not included in the sketch. Try temporarily uninstalling that library, restart the IDE and try again.
aarg:
YEAH!!
It was CircuitPlayground messing around.
SOLVED!
Thanks a lot!
