Hello all!
For my university project I have been experimenting with Capsense Midi to create sensors that would produce sounds of the orchestra. However I have only been able to create the noise of one instrument through Ableton Live at one time. I was hoping to be able to code it so that 4 midis could be used from the same Ableton file e.g one from string, woodwind, brass and percussion. I was wondering if anyone had any advice or examples on how to code this? I'm fairly beginner to arduino so all help would be much appreciated. I tried an example below to try and open several midi however it struggles to upload and when it does, it doesn't work. Please help!
MIDI.begin(1); // Launch MIDI and listen to channel 1
cs_1_3.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
Serial.begin(115200); // put your setup code here, to run once:
MIDI.begin(2); // Launch MIDI and listen to channel 2
cs_4_6.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
MIDI.begin(3); // Launch MIDI and listen to channel 3
cs_7_9.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
MIDI.begin(4); // Launch MIDI and listen to channel 4
cs_11_13.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
