Several sensors trying to access one pump relay at the same time (irrigation)
I'm trying to set up an irrigation system for my daughter-in-law's gardens at our cottage. The garden area are separated so I need three or four sensors/relays. In addition the water pressure is low so we have an auxiliary 12 v pump in the battery shed that is about 20 meters from the gardens.
Essentially it will be three or four capacitance soil sensors that would be placed in various different gardens around the property. When the soil is dry it will turn on a sprinkler... either attached directly to the sensor, or through a relay. No problem there. The problem is that there is low water pressure. In order to get enough pressure the system will have to turn on the pump (in the shed) at the same time, then turn it off when the sensor tells it the specific site has enough water. Still easy enough.
The problem is that there are SEVERAL wireless sensors communicating with the pump, and they will inevitably conflict. For instance one sensor will say that it's finished, and want to shut off while another will say "Hey wait a minute! I'm still using this pump!" So I'm not sure how to design the system to deal with these conflicts.
I'm thinking of using nodemcu ESP8266 as the Arduino units. There would be a soil sensor/nodemcu/relay to turn on the sprinkler at each site. There would be a nodemcu/ relay at the pump site.
I've chosen ESP8266 rather than NRF24L01 units (which I have drawer full)because the next step would be to connect the system to the internet to send updates to her.
Hopefully that's enough information for anyone out there how to come up with a solution to solve
potential conflicts coming from the soil sensors.
Tnx in advance for any advice.
That is basically your solution. Each sensor/Nodemcu should communicate its status (using water, idle) to the pump/nodemcu.
The pump/nodemcu turns on when there is at least one sensor/nodemcu raising its hand (demanding water), and off when none are.
There are multiple ways of course.
You could set a boolean for each sprinkler that's active and clear it when it's done.
When you turn one off, if no boolean indicators are set, turn the pump off too.
Alternatively, just do one sprinkler at a time - for watering, why do you care about doing them all.
Beware of overwatering - apparently it takes a while for the soil to soak up the water and indicate to the sensor that it's done. You might water each sensor that reads dry for a minute (or whatever) and then wait a while before checking again.
how far apart are the nodes?
does the area have global WiFi coverage
the ESP8266 only supports WiFi which has limited range - e.g. 10-20metres depends of environment (walls, trees, etc)
you could use ESP-MESH if the nodes are within range of each other
Conceptually, you need an OR-gate.
As long as one of the sensors demands that the pump is on, it will stay on. If you drive the relay with an open-collector/open-drain transistor connected to each sensor, or a relay driver such as a ULN2803, that will work.
Hi Horace:
The three gardens are about 10 meters apart - line of site
The gardens are about 50 meters from the pump/battery house - line of site
The nodes are all about 50 meters from the wifi router
We basically have metered internet. In the water tank system you helped me with last year I have it set up to turn on once an hour for a minute to get a reading and send it to the internet. I'd do the same with this system.
thanks for the reply. I AM aware of the distinction, sorry I didn't articulate clearly. Regarding of checking the garden myself, I'd happily do that (I enjoy watering) but because it's a summer cottage there is often no one there for a week to ten days.
Can the pump supply 4 sprinklers at the same time?
digitalWrite(pumpPin, sensor1 || sensor2 || sensor3 || sensor4);
Yes, it's pretty hefty marine pump, so no problem supplying four sensors.
think you need to carry out some WiFii tests with the nodes to determine transmission distance, e.g. set up an access point on a central node and see if others can access it
ESP-MESH could be a solution - one the nodes could switch to be a WiFi station to connect to the internet every hour to upload data
you may need to take account of overwatering one area while watering another
could you have a solenoid valve on each node to ensure areas are only watered when required?
the central pumps is switched on only when water is required
I thought that was sort of my plan. For instance lets say at 1:00 garden sensor A decides that it's area is dry so it turns on the relay which opens the sprinkler(valve) and at the same time sends a message to the pump to turn on. As a result Sensor A's area is now being watered.
At 1:30 Sensor B determines that it's area is dry and turns on its sprinkler(valve) and sends a message to the pump. However since the pump is already on it ignores the second request to turn on.
At 2:00 Sensor C determines it's dry and turns on its sprinkler and sends yet another message to the pump to turn on - which, since it's on, the pump ignores.
At 3:00 sensor A detrmines that the garden has enough water and turns of the valve and sends a message to the pump to turn off. Now this is where it gets interesting. Since Sensors B and C still want water, the pump has to ignore sensor A's command and keep the water on. Since sensor A turned off the sprinkler (valve) at its location no water is going to come through to that area, which is what we want. So the pump ignores the request and keeps running.
At 3:30 Sensor B has had enough and shuts off its sprinkler (Valve) and sends a command to the pump to shutoff, but since Sensor C still needs water, it keeps going until sensor C sends it's command and finally since no sensors no longer need water it finally shuts off.
My guess is (with my limited programming skills) that some sort of Boolean commands might be able to solve this.
Thoughts?
each node could send a simple sprinkler on/off status to the pump controller - if any are on the pump is switched on else off, e.g.
if(A_on || B_on || C_on || D_on ) switch_on _pump()
else switch_off_pump();
what about something like this for the pump?
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
// Wi-Fi credentials
const char* ssid = "YOUR_WIFI_SSID";
const char* password = "YOUR_WIFI_PASSWORD";
// Pump controller port
unsigned int localPort = 3333;
// Pump relay pin
const int pumpRelayPin = D1;
WiFiUDP udp;
// Keep track of active requests
bool sensorRequests[3] = {false, false, false};
  connectToWiFi();
  udp.begin(localPort);
  pinMode(pumpRelayPin, OUTPUT);
  digitalWrite(pumpRelayPin, LOW); // Initially turn off pump
  int packetSize = udp.parsePacket();
  if (packetSize) {
    char packet[2];
    udp.read(packet, 2);
    int sensorId = packet[0] - '0';
    bool requestStatus = packet[1] == '1';
    if (requestStatus) {
      handleRequest(sensorId);
      handleRequestRemoval(sensorId);
void handleRequest(int sensorId) {
  sensorRequests[sensorId] = true;
  if (needsWater()) {
    // Turn on pump
    digitalWrite(pumpRelayPin, HIGH);
void handleRequestRemoval(int sensorId) {
  sensorRequests[sensorId] = false;
  if (!needsWater()) {
    // Turn off pump
bool needsWater() {
  return sensorRequests[0] || sensorRequests[1] || sensorRequests[2];
void connectToWiFi() {
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
you can probably simplify to
digitalWrite(pumpRelayPin, packet[1] == '1');
are you saying replacing the six lines with the single line? Can you explain how that works?
thanks
Okay I think I get it. I've updated the code that could run on the sensor or pump. Would it work?
// Sensor Node or Pump Controller Code
// Pump controller IP address and port
IPAddress pumpControllerIP(192, 168, 1, 100);
unsigned int pumpControllerPort = 3333;
// Sensor pin (for sensor nodes)
const int sensorPin = A0;
// Sensor ID (0, 1, or 2 for sensor nodes, -1 for pump controller)
const int sensorId = -1;
// Pump relay pin (for pump controller)
WiFiUDP udp;
// Keep track of active requests (for pump controller)
  connectToWiFi();
  if (sensorId == -1) {
    // Pump controller setup
    udp.begin(pumpControllerPort);
    // Sensor node setup
    udp.begin(WiFi.localIP(), pumpControllerPort);
    // Pump controller loop
    if (packetSize) {
      char packet[2];
    // Sensor node loop
    int moisture = analogRead(sensorPin);
    bool soilIsDry = moisture < 300; // Adjust threshold as needed
    if (soilIsDry) {
      sendRequest();
      removeRequest();
    delay(3600000); // Check every hour
// Sensor node functions
void sendRequest() {
  char message[2] = {sensorId + '0', '1'};
  udp.beginPacket(pumpControllerIP, pumpControllerPort);
  udp.write(message, 2);
  udp.endPacket();
void removeRequest() {
  char message[2] = {sensorId + '0', '0'};
  udp.endPacket();
// Pump controller functions
  if (needsWater()) {
    digitalWrite(pumpRelayPin, HIGH); // Turn on pump
    digitalWrite(pumpRelayPin, LOW); // Turn off pump
bool needsWater() {
// Common function
I assume your packet from a node consists of 2 ints (suggest use bytes)
  1. packet[0] is node ID
  2. packet[1] is '1' for switch on pump '0' for switch off pump
in the statement
the expression packet[1] == '1'
if packet[1] is '1' returns 1 switching on pump else 0 switching off pump
could be extended for multiple nodes
HI Horace:
As always, thanks for your help. You're right, using bytes makes more sense. I've altered the code to do that and added some more code so the sensors can turn on or off the relay controlling the sprinkler(valve) wired to them. Let me know what you think of the code or if you spot any errors.
// Sensor pin and relay pin (for sensor nodes)
const int relayPin = D1; // Pin connected to the relay for the sprinkler valve
WiFiUDP udp;
  connectToWiFi();
    pinMode(relayPin, OUTPUT);
    digitalWrite(relayPin, LOW); // Initially turn off the sprinkler valve
    if (packetSize) {
      byte packet[2];
      int sensorId = packet[0];
      bool requestStatus = packet[1] == 1;
    // Sensor node loop
    if (soilIsDry) {
      sendRequest();
      digitalWrite(relayPin, HIGH); // Turn on the sprinkler valve
      removeRequest();
      digitalWrite(relayPin, LOW); // Turn off the sprinkler valve
  byte message[2] = {sensorId, 1};
  udp.endPacket();
  byte message[2] = {sensorId, 0};
  udp.endPacket();
  digitalWrite(pumpRelayPin, needsWater()); // Turn on pump if any sensor needs water
  digitalWrite(pumpRelayPin, needsWater()); // Turn off pump if no sensor needs water
bool needsWater() {
// Common function
Thanks.
I've updated the code with some serial screen print commands to follow along:
WiFiUDP udp;
  connectToWiFi();
    Serial.println("Setting up pump controller...");
    Serial.println("Pump controller setup complete!");
    Serial.print("Setting up sensor node ");
    Serial.print(sensorId);
    Serial.println("...");
    Serial.print("Sensor node ");
    Serial.println(" setup complete!");
    if (packetSize) {
      Serial.println("Received packet from sensor node...");
      byte packet[2];
        Serial.print("Handling request from sensor node ");
        Serial.println(sensorId);
        Serial.print("Handling request removal from sensor node ");
    // Sensor node loop
    if (soilIsDry) {
      Serial.println(" needs water, sending request...");
      sendRequest();
      Serial.print("Turning on sprinkler valve for sensor node ");
      Serial.println(" has enough water, sending removal request...");
      removeRequest();
      Serial.print("Turning off sprinkler valve for sensor node ");
  udp.endPacket();
  udp.endPacket();
  bool pumpStatus = needsWater();
  Serial.print(" needs water. Pump status: ");
  Serial.println(pumpStatus ? "ON" : "OFF");
  digitalWrite(pumpRelayPin, pumpStatus); // Turn on pump if any sensor needs water
  Serial.print(" has enough water. Pump status: ");
  digitalWrite(pumpRelayPin, pumpStatus); // Turn off pump if no sensor needs water
bool needsWater() {
// Common function
    Serial.print(".");
  Serial.println("\nConnected to WiFi");
Don't forget that UDP is send and forget - the pump controller may miss requests from the sensors. Consider carefully what will happen if one is dropped.
Does it matter for example if the sprinkler is turned off, but the master is still running the pump.
