several unit communication problem
Hi i am working on a project and i have a really big problem in coding
I am working with 10 arduinos using 8 channels on each working
i need a way to send different codes to them all at once
For example send "mp" to board1 and "mn" to board 2 at the same second without any delay between them
am using xbee s1 as a radio module
Connect the Master's Tx to the Rx on the slaves. All can 'listen' while 1 talks.
If you need the slaves to be able to talk back, then a different hardware solution is needed.
this is a piece of the code present on the master board
Serial.print('w1'); Serial.print('w2');
Serial.print('off1');
delay(100);
Serial.print('w1');
delay(100);
Serial.print('w1');
delay(100);
and this is a piece of the code present on one of the slave boards
if(val=="w1"){
digitalWrite(mk,HIGH);
But what happens is that the action doesn't happen on the two boards at once
delay(100);
Serial.print('w1');
delay(100);
Serial.print('w1');
delay(100);
if(val=="w1"){
and this one is found on the second board
if(val=="w2"){
But what happens is that the action doesn't happen on the two boards at once there is a slight delay
any help would be appreciated
am using xbee s1 for communication
If someone would be able to help me through a skype conference it would be great
This is the same question as in your other Thread.
Don't Double Post.
I am asking the Moderator to merge them.
...R
I am not familiar with the XBee but I have done this sort of thing with another 2.4GHz transceiver.
In my system the slaves are always listening. The master sends a message with an ID number for a particular slave. When the slave detects its own ID number it replies before it does anything else and the master will listen for a very short period for that reply. It would be easy to have a special ID number that all the slaves would treat as a message for themselves that should be acted on but not replied to.
In my system each slave expects to get a message within X seconds and if i doesn't it will stop working, but will keep listening.
...R
Single quotes are for single characters!
Robin2:
Don't Double Post.
...R
Merged
