Hello everyone.
I am working a project where I want to use a LCD Screen and a 4 Seven Segment Display
problem
The 4 seven segment display does not display anything when I initialize the LCD in the void setup
lcd.init();
lcd.clear();
lcd.backlight();
Without these 3 lines the 4 seven segment display works. My code is provided below.
My guess is that both libraries use I2C
Please suggest me a solution and Thank you in advance.
#include "SevSeg.h"
SevSeg sev_disp;
LiquidCrystal_I2C lcd(0x27,16,1);
#define r_led 24
#define y_led 26
#define g_led 28
int button = 30;
int button_state = 0;
int count = 10;
int newcount;
int i = 1;
unsigned long previous_time = 0;
unsigned long current_time;
pinMode(r_led, OUTPUT);
pinMode(y_led, OUTPUT);
pinMode(g_led, OUTPUT);
pinMode(button, INPUT_PULLUP);
lcd.init();
lcd.clear();
lcd.backlight();
byte numDigits = 2;
// D1, D2,
byte digitPins[] = {2, 3 };
// A, B, C, D, E, F, G, DP
byte segmentPins[] = {6, 7, 8, 9, 10, 11, 12, 13};
bool resistorsOnSegments = true; // 'false' means resistors are on digit pins
byte hardwareConfig = COMMON_ANODE; // See README.md for options
bool updateWithDelays = false; // Default 'false' is Recommended
bool leadingZeros = true; // Use 'true' if you'd like to keep the leading zeros
bool disableDecPoint = false; // Use 'true' if your decimal point doesn't exist or isn't connected
//Initialize sevseg object.
sev_disp.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments,
updateWithDelays, leadingZeros, disableDecPoint);
sev_disp.setBrightness(90);
void loop(){
current_time = millis();
if(current_time - previous_time == 1000){
previous_time = current_time;
newcount = count - 1;
count = newcount;
sev_disp.setNumber(count, 0);
if (count == 0) count = 11;
sev_disp.refreshDisplay();
