I am using the sevseg library, and am wanting to display the output of my ethanol content sensor on the 3 digit 7 segment display. I can display the variable with the ethanol content, which has a range of 0-99 without any issues. on the left-most digit, I want to display "E" for ethanol, so the display reads "E37" if it is 37% ethanol. my issue is, I cannot figure out how to display both. I can display a string, OR I can display a number...
As a simple test, I am using the following code:
#include "SevSeg.h"
SevSeg sevseg;
int V = 85;
void setup(){
byte numDigits = 3;
byte digitPins[] = {10, 11, 12};
byte segmentPins[] = {9, 7, 6, 5, 4, 3, 2, 13};
bool resistorsOnSegments = false;
bool updateWithDelaysIn = true;
byte hardwareConfig = COMMON_CATHODE;
sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments);
sevseg.setBrightness(10);
void loop(){
sevseg.setChars("E");
sevseg.setNumber(V, 1);
sevseg.refreshDisplay();
