Hi everyone,
I have a problem with using SFM 3000 flow meter sensor with arduino. the default code uses Wire library. Unfortunately, when i use the code bellow, the code shows no result on the serial. when i searched for the problem , i found that there is a problem with Wire library when dealing with I2C sensors which can be solved if WSWire librabry is used. Unfortuantely, when i use WSWire libraby, the serial show only one constant reading which is 239.53.
Note : i changed in the codes of the sensor library by replacing <Wire.h> with <WSWire.h>
Regards,
the library used to run the code :
the library used for WSWire:
#include <Wire.h>
#include <sfm3000wedo.h>
SFM3000wedo measflow(64);
int offset = 32000; // Offset for the sensor
float scale = 140.0; // Scale factor for Air and N2 is 140.0, O2 is 142.8
Wire.begin();
delay(500); // let serial console settle
// initialize the sesnor
measflow.init();
Serial.println("Sensor initialized!");
unsigned int result = measflow.getvalue();
float Flow = ((float)result - offset) / scale;
Serial.print("Flow: ");
if (result >= 0) {
Serial.print(" ");
Serial.print(Flow, 5);
Serial.print("\n");
delay(10);
