Hi guys,
I've got this servo in my robotic arm, before as i checked it without construction of a robot it worked, but now, it won't. i've update to Ardu the sweep example, nothing happens, i've checked him with myservo.read() and he's always 93 degree.
i've wired it up correctly, red to 5.7V, brown 0v and orange to Ardu. Ardu and my generator have bridged 0v.
i've also tried to attach it to differend pins, and tell him to move by myservo.write() myservwo.slowmove() and myservo.writeMicroseconds(). Nothing works
Also servo after attaching haven't any resistance to move it, i can just move it without any problems <Ampers didnt rise when i'm moving it>
All other servos are working, like 2x SG-5010 or M160mg
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(4); // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
Yeap, i Have generator which can handle max 5 Amps and 60V
As i said, other servos are working, but this SG90 won't, before, smth like day ago it worked...
Yeah, from 5 to 6.5 V and Amps about 2.5A for all servo. Now i have 5.6V and 2.5A. its enough, while all of them are moving they didnt take more than 1A.
Dont think its a faulty servo, because before it worked perfectly.
Start off with a basic test such as the "Sweep" although I like to use the "Knob" example because it allows one to play with the angle of the servo (also good for arming an ESC).
Plug in a good servo to see it work then try your bad servo.
Maybe the wires got a little wiggled to much and you have a bad connection inside the servo.
Okay. I checked the servo inside. Connections from microcontroller was good. But. I saw a scratch on microcontroller. Dont know if u Can spot it on this pic, but i think this scratch was caused with some error with microcontroller, and higher current than expected, is my thinking good? Or it could be something else?
