i have a device with a SH1740T2PA Buzzer feeded by a 501B-8P circuit, pins 5 CLK output and 6 S0. I seached and didn't find it's datasheet. How to make sure the tension and if it's AC or DC?
I need to tap from this buzzer to a GPIO of a D1 MINI.
Arduinos only output 5V or 3v3, depending on they type of processor.
Also you can get DC or pulsed (PWM) DC. If you want AC then connect to the buzzer through a capacitor.
Those are the wrong words to use. You should use the words "Active buzzer" for one that uses only a DC voltage to sound it or stop the sound. Or a "Passive buzzer" for one that requires an AC signal in order to make it sound.
This is easy to do an experiment your self. Just connect the buzzer briefly between 3V3 and ground. Then if it makes a sound then it is an active buzzer, if not it is a passive one.
