Hi everyone,
I'm using a Portenta H7 board, and I'm not very experienced with MCUs. Let me explain my situation. I want to share a variable between the M4 and M7 cores—this variable could be a boolean (true or false) or an integer (1 or 0).
Why? I plan to run a loop on the M4 MCU that checks if a switch is pressed. If it is, the variable will change from 0 to 1. On the other MCU, there will be a long process of sampling and writing occurring within a loop function. What I want is to verify at the beginning of each loop if the switch is pressed, meaning if the variable is 0 or 1.
I've tried using separate sketches for M4 and M7, sharing a header file in which I define the shared variable.
Here is the code:
Header File:
#ifndef SHARED_DATA_H
#define SHARED_DATA_H
#include <mbed.h>
// Declare a volatile shared integer
volatile int sharedInt __attribute__((section(".SHARED_RAM")));
#endif
M7 code:
#include "SharedData.h"
bootM4();
Serial.print("M7 read sharedInt: ");
Serial.println(sharedInt);
delay(1000); // Read every second
M4 code:
void setup() {}
sharedInt++; // Increment the shared integer
delay(1000); // Increment every second
