Hi all,
I spent a great deal of time this week on getting a LCD03 from Devantech up and running.
My original set-up: ArduinoBT -(serial TX_line PIN1)-> ArduinoMini -(softserial)-> LCD03.
And of course all the ground lines connected.
I discovered that when communicating to the display at a boutrate of 9600 and getting data over the serial line from the Blutooth Arduino (at 115200 boutrate), that even when I did not read from the serial bus there was still disturbance on the display.
It might be a case of shielding, but it seemed more fundamental. So after a lot of tweaking and peaking I decided to change to I2C.
My current set-up: ArduinoBT -(serial TX_line PIN1)-> ArduinoMini -(I2C)-> LCD03.
Important notice is that I2C communicates with the Arduino with 7bits of information while the address of the LCD is 8 bits. You have to skip the least significant bit so my LCD can be called using 63 as address in stead of C6.
I hope this information might be valuable for anyone.
