hello guys i want to share a signal from a VR sensor.Its possible?Also i got 3x LM1815n its possible to use em? if so can you provide any scheme of how this could work
thanks
Share what sort of signal, and with whom?
LM1815n seems to be a zero-crossing detector for mains AC motor circuits. I'm not sure what you would so with that in a VR rig.
It would also be helpful to know which VR sensor.
im trying to make a digital tacho for a very old bike and when im getting the signal from the vr sensor the bike wont start
So "VR" as in "variable reluctance"? Not virtual reality?
Put that in your thread title to attract more experts.
motoGuyDIY:
What is causing the sensor to produce the signal?
Paul
How do you know the sensor works?
Why have you not answered the question in reply #1?
the signal is generated by the rotation of the crankshaft wheel
the crankshaft wheel got some magnets that they are evenly spaced it so every time a magnet is on the sensor
signal is positive else is negative and that generates a wave form
if the sensor had a problem then the bike wont start becouse it cant fire the ignition without it.but it works normaly and when im trying to connect the lm1815 in the same line the bike wont start
