Hey, I’m new to arduino world and I don’t know much yet about how things work so I wanted to combine example code with readings from DHT11 temp and humidity sensors with simple web server (I have ethernet shield on my arduino uno r3).
Exaple code for dht11 works like a charm, same for simple web server but together they just won’t load. After i put the server addres in my browser it tries to load for a minute or two and then throws timeout error, after i remove reading functions from web server it works without problems.
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
#include <idDHT11.h>
int idDHT11pin = 2; //Digital pin for comunications
int idDHT11intNumber = 0; //interrupt number (must be the one that use the previus defined pin (see table above)
//declaration
void dht11_wrapper(); // must be declared before the lib initialization
// Lib instantiate
idDHT11 DHT11(idDHT11pin,idDHT11intNumber,dht11_wrapper);
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
dht11 = DHT11;
#define nSensores 3
int puertos[nSensores];
float fHumedades[nSensores];
float fTemperaturas[nSensores];
int iNVisitas=0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xEE, 0xEE };
byte ip[] = { 192,168,1, 177 };
Server server(666);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
void dht11_wrapper() {
DHT11.isrCallback();
// listen for incoming clients
DHT11.acquire();
while (DHT11.acquiring());
int result = DHT11.getStatus();
switch (result)
case IDDHTLIB_OK:
case IDDHTLIB_ERROR_CHECKSUM:
Serial.println("Error\n\r\tChecksum error");
case IDDHTLIB_ERROR_TIMEOUT:
Serial.println("Error\n\r\tTime out error");
case IDDHTLIB_ERROR_ACQUIRING:
Serial.println("Error\n\r\tAcquiring");
case IDDHTLIB_ERROR_DELTA:
Serial.println("Error\n\r\tDelta time to small");
case IDDHTLIB_ERROR_NOTSTARTED:
Serial.println("Error\n\r\tNot started");
default:
Serial.println("Unknown error");
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println(DHT11.getHumidity(),2);
client.println(DHT11.getCelsius(),2);
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
when i remove these lines
DHT11.acquire();
switch (result){(…)}
page loads without problems but with them, just wont do anything
