Sharing grounds on a PCA9685
I am using these servo driver boards with an Arduino Uno to drive many LEDs. Can I just jump and share the grounds?
I accidentally hooked up the wrong grounds and noticed the LEDs still operated as normal. Wasn't sure if this was safe or I may damage something. I am not currently using any resistors as the board max amperage is not enough to damage them. I am only using the PWM and Ground pins.
If I can, this would clean up the project immensely by reducing the volume of wiring.
HiLetgo 2pcs PCA9685 16 Channel 12-Bit PWM Servo Motor Driver IIC Module for Arduino Robot https://www.amazon.com/dp/B07BRS249H/ref=cm_sw_r_cp_api_glt_fabc_6NA5N2NNZ11M7CMXV98X?_encoding=UTF8&psc=1
Thanks!
You have us puzzled. What do you see as "right" and "wrong" grounds?
Each LED has a PWM pin and the corresponding GND. I mistakenly swapped some of the ground jumpers on the wrong pins so that some LEDs where connected to the adjacent ground pin and not the corresponding ground pin.
I noticed that they still operated but was worried about letting the magic smoke out.
All ground pins are - or always should be - exactly the same electrical connection.
There are some reasons for connecting the ground in the right place, but not in this situation. The adjacent ground pins are essentially interchangeable. :+1:
Do you have a DMM?
Tom... :smiley: :+1: :coffee: :australia:
Yes I do. Are you hinting I should see if there is continuity across the GND pins?
Yes , with the power OFF.
Would dispel your doubts.
You have a very powerful diagnostic tool there...
Tom.... :smiley: :+1: :coffee: :australia:
I tested the continuity per your advise and proved that all the ground are linked together. I was happy to remove all that wiring.
Thanks!
This Topic has been locked as it is the identical or too similar your other post.
Please use the original post and do not duplicate.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
