Morning gang...
I've salvaged one of these from an old copier, but it doesn't seem to work. Output is meant to be high when the light is interrupted, but when I put 5v on Vcc pin 1 and Ground pin 3, I get nothing out of Vout pin2 and ground with the light interrupted or not.
Reading the data sheet http://sharp-world.com/products/device/lineup/data/pdf/datasheet/gp1a73a_e.pdf, I see that Vout should be up to 90% of Vcc with RL = 47k. Does that mean this is some kind of switching device (like a PC power supply which only produces voltage under load), and that I should put a 47k load into play?
If it does need a load, just for testing purposes where would that go: Vout to Ground?
TIA,
Jim
(on the other hand, of course the sensor may be broken....)
