Dear
I'm built 7 Epoxy Board Breadboard (xbee, pro mini, rtc and 2 ir sharp 3v3 pololu) each board powered by 3 LS33600 batteries in parallel (3.6V, 51Ah, supported max pulse 250mA) with Schottky diode. On the board : with + The + the -.. With - nothing more.
I am a simple threshold crossing test.
wake_IR(IR1_pin_sleep); sleep_IR(IR2_pin_sleep); delay(10);
sensorValue1 = analogRead(IR1_pin_data);
sleep_IR(IR1_pin_sleep);wake_IR(IR2_pin_sleep); delay(10);
sensorValue2 = analogRead(IR2_pin_data);
sleep_IR(IR2_pin_sleep);if (sensorValue1>MAX)
detected_object_ir1++if (sensorValue2>MAX)
detected_object_ir2++
On PC everything works perfectly but not on battery. Only 3 cards are walking good, others count over a factor 100 or more !! I train and do not understand, it's the same code, the same hardware, new batteries, the welds are average but on pc everything works, I do not understand and I can not find a line of research?
it should add resistance? capacitor? I do not know .
Philippe.
