Sharp IR error
Dear Arduino friends,
I have a Sharp GP2YA41SK0F IR sensor connected to my Arduino Uno and I am getting an error saying ‘class SharpIR’ has no member named ‘distance’ (please see copied error message below).
It worked a couple weeks ago when I first tested it, but now this error. Does anyone have a suggestion as to what may be causing this?
(The code I am trying to load is below the copied error message)
(Copied error message)
Arduino: 1.8.8 (Windows 10), Board: “Arduino/Genuino Uno”
C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_30835\SharpSensorCm.ino:50:26: warning: large integer implicitly truncated to unsigned type [-Woverflow]
SharpIR SharpIR(ir, model);
C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_30835\SharpSensorCm.ino: In function ‘void loop()’:
SharpSensorCm:62:19: error: ‘class SharpIR’ has no member named ‘distance’
int dis=SharpIR.distance(); // this returns the distance to the object you’re measuring
Multiple libraries were found for “SharpIR.h”
Used: C:\Users\jlcel\Documents\Arduino\libraries\SharpIR
Not used: C:\Users\jlcel\Documents\Arduino\libraries\robojax-sharp_IR-master
Not used: C:\Users\jlcel\Documents\Arduino\libraries\SharpIR-master
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
(Code I am trying to load)
#include <SharpIR.h>
#define ir A0
#define model 430
// ir: the pin where your sensor is attached
// model: an int that determines your sensor: 1080 for GP2Y0A21Y
// 20150 for GP2Y0A02Y
// (working distance range according to the datasheets)
delay(2000);
unsigned long pepe1=millis(); // takes the time before the loop on the library begins
Serial.print("Mean distance: "); // returns it to the serial monitor
Serial.println(dis);
unsigned long pepe2=millis()-pepe1; // the following gives you the time taken to get the measurement
Serial.print("Time taken (ms): ");
Serial.println(pepe2);
So, why do YOU think the class has a member named distance()?
Post a link to the library, so wen can see what members it does have.
