I am using an Arduino Uno board to control a non modified Hitec servo (0 to 180 degree) and a sharp IR. The sensor is glued on so that it is facing “forward” when I drive the servo to 90 degrees. My goal is to have the servo do a sweep from 0 degrees to 180 degrees while I take measurements from the Sharp IR so I can get a feel for what is in front of my robot. I have posted the following test code I am working on to make this work. I have the line that actually stores what the sharp IR is reading commented out below. With it commented out this is the fastest I can get him to turn his “neck” from 0 degrees to 180 degrees.
For now I would be happy to get a reading every 5 degrees. So I store the reading from the sensor every 5 degrees in my array and then print it out when it is done turning his neck. My problem is he is about 15 degrees off. I know this because i set the delays for much longer so he turned his head very slow. I place objects directly in front of him and on his sides. Then I compared this slow accurate output to my output with the following code–but with the one line un-commented. I can get accurate readings if I make the delay large enough that he is turning his head about ½ or [ch8531] the speed he is currently turning.
I feel like I shouldn’t have to increase the delay because at the point in code where he makes a reading, if he is pointing to where I think he should be (the last neckservo.write position), the reading should be accurate. Does anyone have any ideas.
p.s. I realized on my read through that when I said accurate I am not clear. I believe I am receiving accurate data in distance but that it is off by 15 degrees. So my accurate readings show an object close by at val[90] and val[95] my code below shows the object close by in val[115] and val[120].
Thanks in advance for any help. I really do appreciate it.
#include <SoftwareServo.h>
SoftwareServo neckservo;
int test_flag = 1;
int c;
int eyes = 0;
int val[180];
neckservo.attach(2);
void look_left(int limit)
for(c = 0; c < limit; c++)
neckservo.write(0);
delay(15);
SoftwareServo::refresh();
while(test_flag)
look_left(100);
for(c=0; c <= 180; c = c+5)
neckservo.write(c);
//val
= analogRead(eyes);
neckservo.write(c+1);
delay(3);
neckservo.write(c+2);
delay(3);
neckservo.write(c+3);
delay(3);
neckservo.write(c+4);
delay(3);
neckservo.write(c+5);
delay(3);
Serial.print("val[");
Serial.print(c); Serial.print("]: ");
Serial.print(val[c]);
Serial.print("\n");
test_flag = 0;
