Sharp IR sensor filtering
Hi people,
Ive come across the need to filter the noise out of my very noisy sharp IR sensor for my rover bot. it seems the general consensus is to solder a 10uf capacitor from vcc to ground however at the electronics store icouldnt find any 10uf non polarised caps so i had to settle for 22uf (polarized film caps) and 0.1uf ceramic caps.
which is the better for me to use? can i even use polarized capacitors for this application? i do have alot of resistors here too and i see some people recommend soldering a resistor in parralel with the output pin if i recall correctly.
also as a side question to this. i notice my readings became in accurate on the rover when the servo is moving the sensor left and right in a sweep. if the servo stops the reading is stable (sort of with noise) however if it is moving i can get readings like 3 then 150 in the same position. Is it possible that the servo is generating electrical noise that the sensor picks up?
Thanks :wink:
just noticed i made this in the wrong forum doh!
You can connect two of your polarized capacitors back to back (plus to plus or minus to minus) to make it non-polarized.
Move the sensor by hand while taking readings to see if it's the physical movement or servo noise causing the problem. I doubt its RF noise from the servo, but if it is you can reduce this by winding the servo lead around a ferrite toroid : http://www.goldmine-elec-products.com/products.asp?dept=1050 If you have an old computer power supply in your junk-box you can probably pull one out of that.
