hi everyone,after reading allmost all post around here and google,hope 2 get my answers here.I found hundred of examples of Ir conected to Atmegas that light up a Led when get close to object,but not even one example on how to make a toogle switch.Im not the only one looking for codes like this,truth is this subject is avoided,anyway..I wanna do a simple toogle switch,with the arduino Duemilanove and the Sharp 2Y0A21 ir sensor,that can light a Led.So far i can only make it like momentary switch:
+LED on pin 13
+DATA from ir on pin analog 0
// we read the sensor Value
int Value = analogRead(A0);
// we maps the value
int sensorValue = map(Value, 0, 1024, 0 , 200);
// turn on the led1 when the value is beetween 50 and 100
if ( sensorValue > 50 && sensorValue <300){
digitalWrite(13, HIGH);
else {
// turn off the two leds
digitalWrite(13, LOW);
I make program using analog sound sensor and DHT22 humidity and temperature sensor. When I see serial monitor, it print sensor value so slowly. In this case the analog sound sensor become not responsive. When I use only analog sound sensor (without DHT22), serial monitor printed analog sensor value so fast. Is there a problem with DHT22 program?
float h = dht.readHumidity();
float t = dht.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h)) {
Serial.println("Failed to read from DHT");
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.println("Temperature: ");
Serial.print(t);
Serial.println(" *C");
int sensorValue = analogRead(A0);//use A0 to read the electrical signal
Serial.println(sensorValue);
Hello all i want to do that Arduino IR swich lighting a led, but i dont know how can you help me please.
I see lots of ppl using a 32khz...etc IR leds resivers, im not so good in electronics but in that case i want to use
a "" 5mm 940nm IR infrared Receiving LED Lamp "" not sure how its works but as i see from the name is the same
led IR receiver like the remote_tv. one i took few of that ones http://www.ebay.com/itm/100Pcs-5mm-940nm-IR-infrared-Receiving-LED-Lamp-/140910365482?refid=store and i want to light a 5mm blue led, and yes for that i will need a 5mm IR transmiter too.
I have all that pices but i dont know to combine them all to work.
I readed lots of forums and tested lost of codes but non of them worked for me.
Please help me i need to build that god dam IR led swich
