Sharp Memory LCD and Arduino GFX issue
I'm working on a little project with a circular Sharp Memory LCD panel, and I'm having some difficulty getting the Adafruit GFX tests running on it. I have gotten one set of tests running, found here on Github: GitHub - MakerDyne/Memory-LCD: Example Arduino class/library for my Sharp Memory LCD Breakout Boards
These tests from MakerDyne perform well, but they are very rudimentary, and I'd like to get the Adafruit libraries working so I have more tools at my disposal. I got the MakerDyne test working by changing the default pixel count from 96x96 to 128x128 (the height and width of my LCD panel), but when I try this with the "Adafruit_SHARP_Memory_Display" sketch, the Arduino compiler says that the Arduino Uno has run out of memory.
From here I tried moving on to another library which used the Adafruit GFX found here: GitHub - hybernaut/SharpMemoryLcd: fork of Craftycoder's Sharp Memory LCD GFX Library
When I tried out this library (and changed the pixel dimensions to 128x128), I was able to get the panel to display something, but the image is very distorted and striped.
Does anyone have advice for how I can get the adafruit graphics to work with my round LCD panel? Please let me know if I've left out any details which might help!
-Jake
Just to clarify some details about the LCD panel itself, it's a 0.99" Sharp Memory Display model LS010B7DH01: http://www.sharpmemorylcd.com/0_99-inch-memory-lcd.html, and the breakout board I'm using is from Kuzyatech: Sharp Memory LCD Breakout A2 | KuzyaTech
It seems that it runs of memory.
Did you manage to rectify your problem? I'm looking at doing something similar with the same component.
