SharpIR + Ultrasonic + GPS Neo6mv2 + GSM sim808 code connect HELP HELP !!!!!!!
Im doing visually empaired people helper project and it means using SharpIR + Ultrasonic + GPS Neo6mv2 + GSM sim808 and i have 2 code and icant connect them. Help me?
versionv2.1.ino (1.69 KB)
gps.ino (2.52 KB)
Help me?
No. You have not said what either program actually does. You have not said what the final program is supposed to do. You have not said what it actually does. How can we help with so little information?
#include <SoftwareSerial.h>
#include "SIM900.h"
#include <TinyGPS.h>
#include "sms.h"
SMSGSM sms;
TinyGPS gps;
SoftwareSerial ss(4, 3);
SoftwareSerial SIM900(7, 8);
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
String strL, strN, message, textForSMS;
char charL[10], charN[10], text[200];
int m = 1;
boolean started = false;
ss.begin(9600);
  gsm.begin(9600);
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  gps.f_get_position(&flat, &flon, &age);
  textForSMS = "Moosa Home"; //testing gps from here
  Serial.println(textForSMS);
  Serial.println(flat, 6);
  Serial.println(flon, 6);
  Serial.print("longitude: ");
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
  Serial.println("");
  Serial.print("latitude : ");
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
  smartdelay(1000);
  Serial.println(""); //till here
  if (m == 5) //send sms on third reading
    Serial.println("XXXXXXXXX"); //to check whether 'if' works
    dtostrf(flat, 4, 6, charL);
    for (int i = 0; i < 10; i++)
  strL += charL[i];
dtostrf(flon, 4, 6, charN);
  strN += charN[i];
message = "Home";
message = message + "/nLat: ";
message = message + strL;
message = message + "/nLon: ";
message = message + strN;
message.toCharArray(text, 250);
Serial.println(text);
if (sms.SendSMS("+999999999999999", text))
  Serial.println("\nSMS sent OK.");
  Serial.println("\nError sending SMS.");
do {} while (1);
m++;
  unsigned long start = millis();
  do
    while (ss.available())
  gps.encode(ss.read());
  } while (millis() - start < ms);
  if (val == invalid)
    while (len-- > 1)
  Serial.print('*');
    Serial.print(' ');
Serial.print(val, prec);
int vi = abs( val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i = flen; i < len; ++i)
  Serial.print(' ');
  smartdelay(0);
  int slen = strlen(str);
  for (int i = 0; i < len; ++i)
Serial.print(i < slen ? str[i] : ' ');
  smartdelay(0);
#define trigPin 4
#define echoPin 2
int bipPin = 8;
int bipPin1 = 9;
int Note = 1;
int Nate = 1800;
int Nite = 1600;
int IRpin = A0; // sensor to pin A0
 Serial.begin (9600);
 pinMode(trigPin, OUTPUT);
 pinMode(echoPin, INPUT);
 long duration, distance;
 digitalWrite(trigPin, LOW);  // Added this line
 delayMicroseconds(2); // Added this line
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10); // Added this line
 duration = pulseIn(echoPin, HIGH);
 distance = (duration/2) / 29.1;
 if (distance >= 400 || distance <= 0){
   Serial.println("Out of range");
 else {
   Serial.print(distance);
   Serial.println(" ult");
  if(distance<=120 && distance>=100)
    tone(bipPin, 20, 30);
  if(distance<=100 && distance>=65)
    tone(bipPin, 50, 60);
 if(distance<65 && distance>30)
    tone(bipPin, 100, 100);
  if(distance>0 && distance<30)
     tone(bipPin, 1, 1);
  float volts = analogRead(IRpin)*0.0048828125;   // value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
  float distance = 65*pow(volts, -1.10);          // worked out from graph 65 = theretical distance / (1/Volts)S
   Serial.println(" shp");
  if(distance<40 && distance>10)
     tone(bipPin1, Nate, distance);
    if(distance>40 && distance<70)
     tone(bipPin1, Note, distance);
   if(distance>70 && distance<100)
     tone(bipPin1, Nite, distance);
 if(distance>100 && distance<300)
  delay(200);                                     // arbitary wait time.
 delay(200);
Why icant ? I wrote sharpir+ultrasonic
and gps+gsm just connect this 2 codes and need sensor codes must be contuinously
anhbaysgalan:
Apparently, English isn't your first language. But, spacing between words is not language dependent...
Yes, you have two codes. No, you do NOT have requirements for the resulting program. No, you have not made any attempt to combine them. Nor are you likely to be successful without any requirements.
Any code that uses two instances of SoftwareSerial is doomed to failure from the get go. Get an Arduino with multiple hardware serial ports, and do not use software serial at all.
First, I suggest you resolve the pin conflicts.
#define trigPin 4
#define echoPin 2
int bipPin = 8;
int bipPin1 = 9;
