Shell command dosent work
Hello,
I have a python script which uploads a .txt file from my sd.
when I log in with ssh and run the command
python /mnt/sda1/Data/upload.py
it is uploading the file and I can see it in my server,
but when I try to run this command with arduino it doesn’t work.
This is my code.
Any ideas?
#include <FileIO.h>
#include <Process.h>
#include <Bridge.h>
  // Initialize the Bridge and the Serial
  Bridge.begin();
  FileSystem.begin();
  while (!Serial); // wait for Serial port to connect.
  Serial.println("Filesystem datalogger\n");
void loop () {
  // make a string that start with a timestamp for assembling the data to log:
  String dataString;
  Process p;
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 2; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) {
      dataString += ",";  // separate the values with a comma
  // open the file.
  File dataFile = FileSystem.open("/mnt/sda1/Data/data.txt", FILE_APPEND);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close(); //close the file
    p.runShellCommand("python /mnt/sda1/Data/upload.py"); //use the upload script to upload it
    while (p.running()); //wait until upload done
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
  delay(2500);
Can you share upload.py too?
yes this is the code nothing hard.
import ftplib
    session = ftplib.FTP('MyServer','username,'pass')
    f = open('data.txt','rb')
    session.storbinary('STOR data.txt', f)
    f.close()
    session.quit()
for today I made a python script and use it at the server.
But running scripts with bridge is important for me I tried other commands like 'rm file.txt' ' mkdir test' etc and they worked.
This is it: use absolute paths
[quote author=Federico Fissore link=topic=242430.msg1739077#msg1739077 date=1401087775]
This is it: use absolute paths [/quote]
And yes, that was the problem, thank you one more time XD
