Shield arduino ethernet
Bonjour
J’ai un shield ethernet pour arduino uno que je n’arrive pas à configurer http://www.lextronic.fr/P28673-ethernet-shield-pour-arduino.html
Voici mon code :
  Web Server
 A simple web server that shows the value of the analog input pins.
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,60);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
	  client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
Normalement je dois pouvoir accéder à son interface via son adresse IP (192.168.1.60) connecté à mon routeur mais je n’y arrive pas.
Une idée?
Bonsoir,
tahsc: Normalement je dois pouvoir accéder à son interface via son adresse IP (192.168.1.60) connecté à mon routeur mais je n'y arrive pas.
Es-tu sur de ton adresse IP local ?
Bonsoir,
L’adresse MAC du shield est-elle celle déclarée dans le code ?
Sur le PC en mode commande si tu tape : ping [adresse IP du shield] à tu un retour ?
PhilAin: Bonsoir, L'adresse MAC du shield est-elle celle déclarée dans le code ? Sur le PC en mode commande si tu tape : ping [adresse IP du shield] à tu un retour ?
bonsoir sur un shield ethernet (W5100) l'adresse MAC est celle injectée par le code, il n'y a pas d'adresse MAC en dur, meme si elles sont livrées avec une etiquette MAC ADRESS :grin:
tahsc: Bonjour
J'ai un shield ethernet pur arduino uno que je n'arrive pas à configurer http://www.lextronic.fr/P28673-ethernet-shield-pour-arduino.html
Une idée?
Je n'ai pas rejoué avec un shield ethernet depuis qq temps, mais je me souviens depuis l'IDE 1.00 qu'il y avait eu qq modifs renseigne tous les parametres, pas seulement mac et ip : Ethernet.begin(mac, ip, dns, gateway, subnet);
Bonjour
Merci de vos réponses je confirme que je suis bien en local et je lui ai définit une adresse IP local proche de celle de mon pc mais je n'ai aucun retour par ping. Sur ce type de shield l'adresse mac est définit par celle renseignée dans le code donc ce n'est pas un problème d'adresse mac.
Je ne vois pas d'ou pourrais provenir le problème
Une idée???
Essaie de ne rien mettre entre ton PC et ta carte.
Connecte ton shield direct sur ton PC pour écarter un problème réseau quelconque. Ensuite coupe ton pare feu et désactive tout anti virus.
Dit nous si tu as toujours le même problème de ping
Autrement Velleman font toujours des notices nickel donc je te conseille de reprendre leur notice de A à Z concernant l'installation, il y a peu être quelque chose que tu as du oublier? Cablage? Déclaration des PINS ?
As-tu essayé avec le code exemple ici: http://www.vellemanprojects.eu/downloads/files/downloads/ka04_sample_code.zip ?
Car apparent il faut déclarer une bibliothèque spéciale: EtherCard.h ?
quelles adresses as-tu utilisé ?
bonjour tu utilise une librairie prevue pour un shield ethernet arduino officiel basé sur un W5100 et ce que tu a acheté est une carte basée sur un ENCJ860. forcement ça va bien moins marcher :grin:
perso je n'avais pas été prealablement voir le lien dans la mesure où :
J'ai un shield ethernet [u]pur[/u] arduino uno
et debut de ton code
  Web Server
reprend tout à zero en essayant l'exemple cité par Christian
j'ai donc téléversé le programme que tu m'a donné mais ou dois je mettre l'adresse IP dans le programme pour pouvoir tester?
Sur l'autre programme, je mettait comme adresse IP 192.168.56.2, l'adresse de mon PC étant 192.168.56.1
tahsc: j'ai donc téléversé le programme que tu m'a donné mais ou dois je mettre l'adresse IP dans le programme pour pouvoir tester?
rapidement regardé le programme attribue l'adresse IP par DHCP déjà regarde ce que cela donne dans le serial monitor lorsque tu utilise le programme 8) connecte toi ensuite avec l'adresse IP attribuée
Quand je met le serial monitor j'ai ...... RIEN!!!
Je précise que j'ai moi meme monté le module (donc soudé) et apparament il y a des contacts partout, sur la prise RJ45 j'ai les deux led allumée.
Je ne vois pas quoi faire
tahsc: Quand je met le serial monitor j'ai ...... RIEN!!!
tu a bien mis le serial monitor à 57600 ? 8)
AHH mercii j'avais oublié de mettre sur 57600.
Mais la il me met DHCP failed
tahsc: AHH mercii j'avais oublié de mettre sur 57600.
Alors ton shield n'est pas reconnu fais des photos (claires , lisibles) de tes soudures
mes soudures m’ont l’air bonnes
Artouste: reprend tout à zero en essayant l'exemple cité par Christian
C'est qui Christian? :grin:
tahsc: mes soudures m'ont l'air bonnes
Pas si bonnes que ça, j'ai l'impression qu'il manque un peu de matière sur certaines avec des pattes dans le vide non?
john_lenfr:
:grin: rendons à Cesar ! désolé je devais finir de lire un autre topic 8)
tahsc:
c’est vite dit :grin:
fais une reprise complete et verifie qu’il n’y ai pas de ponts intempestifs
Et moi je veux bien une photo du dessus pour vérifier l'orientation des composants :grin:
Parce que un condo ou un chip mis à l'envers ça va vite...
