Hi guys! How are you doing? I assembled a Shield Esp8266 Esp12e on Arduino mega 2560 to control relays in the system. But the process to write generate a esptool.FatalError:
"esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header".
Serial port /dev/cu.usbmodem1101
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "/Users/caiosanchezchristino/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/upload.py", line 66, in <module>
esptool.main(cmdline)
File "/Users/caiosanchezchristino/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 3552, in main
esp.connect(args.before, args.connect_attempts)
File "/Users/caiosanchezchristino/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 529, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
As you stated correctly in the topic name, it failed to connect. chances are you need to flick some dip-switches to upload new firmware to the ESP. Check the manual of the shield.
In the next sketch try and set up OTA updates, that will save a lot of hassle.
Thanks for helping @horace and @Deva_Rishi
I believe that's an upgrade isn't solve the problem.. i think about dip-switches makes sense to me because if I keep the reset button of mega pressed, the build are started with success. But process to write exceed the 17s and reset me Mega board and the code aren't written.
@Deva_Rishi Are only available dip-switches on shield Esp selectors right? It's possible set a "jumper" the Mega 2560 too?
I assume you are attempting to program the device by connecting the shields EXTERNAL SERIAL USB ADAPTER CONNECTION to RX0 and TX0 of the UNO
the shield guide (referenced in post #2) states NOTE: Before mounting the Arduino wiring diagram, you must load a blank code on the board to ensure that the serial USB converter is not being used.
did you do thst?
never attempted to program a shield this way - always used a USB-TTL converter
