shield gps l80 m39
Hello, All!
he did not manage to have the shield reception
I'm working on a project and I need to get to get the location of the GPS but I can not get an answer from the
I would appreciate if you could help me
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 1, TXPin = 0;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
Serial.println(F("FullExample.ino"));
Serial.println(F("An extensive example of many interesting TinyGPS++ features"));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F("by Mikal Hart"));
Serial.println(F("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum"));
Serial.println(F(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail"));
Serial.println(F("----------------------------------------------------------------------------------------------------------------------------------------"));
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
printInt(gps.satellites.value(), gps.satellites.isValid(), 5);
printFloat(gps.hdop.hdop(), gps.hdop.isValid(), 6, 1);
printFloat(gps.location.lat(), gps.location.isValid(), 11, 6);
printFloat(gps.location.lng(), gps.location.isValid(), 12, 6);
printInt(gps.location.age(), gps.location.isValid(), 5);
printDateTime(gps.date, gps.time);
printFloat(gps.altitude.meters(), gps.altitude.isValid(), 7, 2);
printFloat(gps.course.deg(), gps.course.isValid(), 7, 2);
printFloat(gps.speed.kmph(), gps.speed.isValid(), 6, 2);
printStr(gps.course.isValid() ? TinyGPSPlus::cardinal(gps.course.deg()) : "*** ", 6);
unsigned long distanceKmToLondon =
(unsigned long)TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON) / 1000;
printInt(distanceKmToLondon, gps.location.isValid(), 9);
double courseToLondon =
TinyGPSPlus::courseTo(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
printFloat(courseToLondon, gps.location.isValid(), 7, 2);
const char *cardinalToLondon = TinyGPSPlus::cardinal(courseToLondon);
printStr(gps.location.isValid() ? cardinalToLondon : "*** ", 6);
printInt(gps.charsProcessed(), true, 6);
printInt(gps.sentencesWithFix(), true, 10);
printInt(gps.failedChecksum(), true, 9);
smartDelay(1000);
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS data received: check wiring"));
// This custom version of delay() ensures that the gps object
// is being "fed".
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
static void printFloat(float val, bool valid, int len, int prec)
if (!valid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartDelay(0);
static void printInt(unsigned long val, bool valid, int len)
char sz[32] = "*****************";
if (valid)
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz = ' ';
  • if (len > 0)*
  • sz[len-1] = ' ';*
  • Serial.print(sz);*
  • smartDelay(0);*
    static void printDateTime(TinyGPSDate &d, TinyGPSTime &t)
  • if (!d.isValid())*
    _ Serial.print(F("********** "));_
  • else*
  • char sz[32];*
  • sprintf(sz, "%02d/%02d/%02d ", d.month(), d.day(), d.year());*
  • if (!t.isValid())*
    _ Serial.print(F("******** "));_
  • else*
  • char sz[32];*
  • sprintf(sz, "%02d:%02d:%02d ", t.hour(), t.minute(), t.second());*
  • printInt(d.age(), d.isValid(), 5);*
  • smartDelay(0);*
    static void printStr(const char *str, int len)
  • int slen = strlen(str);*
  • for (int i=0; i<len; ++i)*
    _ Serial.print(i<slen ? str : ' ');_
    * smartDelay(0);*
You do have the GPS outside with a clear view of the Sky ?
Can you also read the 'How to use this forum - please read' post at the top of the list, it contains details on how you should have posted your code.
Yes, I already perform the process for three hours, but it does not give any location response
Follow the troubleshooting steps below, they include instructions on how to use a simple GPS echo program that will tell you if the GPS is working;
GPSTutorial
Is the GPS outputting any data? I think step 1 would be to confirm the GPS can output properly and dump the stream to the console. If you're not getting any data, then the rest of the code isn't very useful.
