Shield Yun
Hello,
I try to use the Yùn Shield with my Arduino UNO but it's don't work ...
I follow theses steps : http://wiki.dragino.com/index.php?title=Yun_Shield
But nothing is printing on the Monitor of Arduino IDE ...
What's wrong with this source :
#include <Bridge.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Bridge.begin(); // Initialize Bridge
Serial.println("Test 1");
// set the data rate for the SoftwareSerial port
mySerial.begin(1200);
mySerial.println("Hello, world");
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
Thanks very much for your help !
You better use an Arduino Leonardo for the Dragino Yun Shield.
Pin 0 (RX) and pin 1 (TX) are used to upload a sketch and for the serial monitor. But when the Dragino Yun shield is attached, those pins are used for the Bridge.
You have to disable the serial interface to the computer, as is written here : http://wiki.dragino.com/index.php?title=Yun_Shield#Connect_to_Arduino_Uno
The Arduino Leonardo doesn't use pin 0 and 1, so they can be used for the Bridge.
I already disable the serial interface on my UNO. thanks to that i can upload my sketch without errors
If i have a leonardo i'll use it but i don't (for now :slight_smile: )
I read this : http://www.arduino.cc/en/Main/ArduinoBoardYun?from=Main.ArduinoYUN
I found on this : "A SoftwareSerial library allows for serial communication on any of the Yún's digital pins. Pins 0 and 1 should be avoided as they are used by the Bridge library."
So I use the pin 10 for my input but it don't work ...
Thanks for explaining, I was a little confused.
What did you connect to pin 10 and 11 ? I hope some kind of usb-serial-5V-compatible-adapter.
Have a look at this code:
The Bridge is initialized (it uses pin 0 and 1), and after that the Bridge is overruled when you take over those pins with "Serial.begin(9600);".
In the loop, you also use Serial functions.
The Bridge really needs those pins 0 and 1. That means you can't use 'Serial' anymore, only the software mySerial.
For the moment my UNO+YunShield are powered by my PC with USB.
In the future i want to powered them by DC Jack and battery to avoid PC.
If I can't use Serial.*** and use mySerial to read the pin 10 => how print the "reading" on the IDE ?
That is why a Leonardo is so much easier.
With the Leonardo, the uploading of a sketch, and use of serial monitor is done directly via the USB without the use of pin 0 and 1.
Can you please tell what you have connected to pin 10 and 11 ? Some connect it to RS-232, that could damage the Arduino. If you have connected pin 10 and 11 to a usb-serial-5V-compatible-adapter(converter), then you have an extra serial port on the computer, which can be used by the serial monitor (or any other serial terminal program).
I mentioned "adapter". I ment a small module, a converter. An adapter adapts things. I know, a "power supply" can also be a "adapter", but I ment a converter.
Peter_n:
1+
Unless than Mega or Due, use other type Arduino might not be smart move.
My project is to know my energy consumption and see it with graphics like this : http://christellelacour.fr/teleinfo_edf/
At the beginning I make a set up with Arduino UNO alone and a PC.
Now it's working, I'll try to make it "mobile" and avoid pc to saving and powering.
My diagram is this one : http://domotique-info.fr/wp-content/uploads/2014/04/domotique-info-schema.png
My pin 10 is the equivalent of pin 8 in the diagram above
@sonnyyu : I try to make it work without buying a new card ... if it's not possible I will buy it ... but if it's possible with this, it's better for me :slight_smile:
Elmout:
It's possible with an Uno, but you will get USB serial communications, or Yun Shield communications, you can't have both. This is because the Serial interface (pins 0 and 1) are used for both the USB communications, and the Yun Shield communications. Therefore, if you want to use the Yun Shield, you must disable the Uno's USB interface and never use the Serial object in your sketch.
The Leonardo uses Serial to talk to the USB interface, and doesn't use pins 0 and 1 to do this, that's why it's a better fit. The Leonardo uses Serial1 to talk to pins 0 and 1, which go to the Yun Shield, and therefore you with the Leonardo you can use the USB serial interface and the shield at the same time.
That is a very small circuit to receive serial data. It should be possible to read that with SoftwareSerial.
The TX of the SoftwareSerial is not used yet, you can use that to send messages to the computer, using a usb-serial converter : http://store.arduino.cc/product/A000059
There are many of those usb-serial converters. If you buy one from Ebay, it might have a fake chip.
If you can connect to the Dragino Yun Shield via Ethernet or wifi with the Arduino IDE, you could try the Console at port 6571.
I always use an Leonardo board and always use the serial monitor via usb for messages, because I can't always connect with the Arduino IDE via Ethernet or wifi.
Peter_n:
Why would the size of the circuit have anything to do with the ability to use SoftwareSerial?
SoftwareSerial is best applicable for situations that use high baud rates, and low volume of data. From the schematic, we can't tell anything about the data volume, but it does mention 1200 baud. The software serial library has this to say about baud rates:
**Be circumspect about using 300 and 1200 baud though. The interrupt handler at these rate becomes so lengthy that timer tick interrupts can be starved, causing millis() to stop working during receives.
Despite the circuit being very small, I think it should produce a good digital output signal for the Arduino.
Perhaps the AltSoftSerial would be better in this situation : AltSoftSerial Library, for an extra serial port
I don't understand everthings ...
If I powered the Arduino UNO + Shield Yun by battery instead of USB my code will works ?
If I powered the Arduino UNO + Shield Yun by USB, I can't use SoftWareSerial becasue of the rate of baud ?
How the Dragino Yun Shield and Uno are powered has not to do with the baudrate.
I wrote about an 'adapter', but I ment a 'converter'. Like this one : http://www.arduino.cc/en/Main/USBSerial
The TX pin of the SoftwareSerial could be used with such a converter to show messages on the computer.
What kind of battery do you want to use ? Not a small 9V battery I hope.
Powering the Dragino Yun shield with USB 5V... is that possible ? I think the Dragino Yun shield uses VIN to create power for the wifi/linux/OpenWRT module.
Has someone tried the Arduino Mini Yun?
It should powered with a +5 volt.
Peter : Yes i want use 9V battery like this : http://www.conrad.fr/medias/global/ce/4000_4999/4500/4550/4555/455511_BB_00_FB.EPS_1000.jpg
I can powered my UNO with 9V charger like that : http://www.amazon.fr/Chargeur-Alimentation-compatible-Arduino-Adaptateur/dp/B008QXOMQQ
So what's the problem with a 9V battery ?
The 9V 'chargeur' is okay.
The 9V battery is not okay. The Dragino Yun shield requires some current (100-300mA ?). The 9V battery might last only half an hour.
9V batteries stink! I can't explode a 22uF capacitor with one!
I can work on this project this weekend so I try to use 9V battery for the test.
And it's work !! I receive the info of my power consomation !
So I continu my project and send the datas to my Synology Nas to make the storage in mySQL batabase.
Now my code is this :
#include <Console.h>
#include <AltSoftSerial.h>
#include <HttpClient.h>
char incomingByte;      // a variable to read incoming Console data into
AltSoftSerial altSerial;
  Console.begin();  // Initialize Console
  // Wait for the Console port to connect
  while (!Console);
  pinMode(8, INPUT);
  altSerial.begin(1200);
  // On récupère la trame téléinfo
  char CaractereRecu ='\0';
  String Trame;
  while(CaractereRecu != 0x02) // boucle jusqu'a "Start Text 002" début de la trame
       if (altSerial.available()) {
         CaractereRecu = altSerial.read() & 0x7F;
    while(CaractereRecu != 0x03) // || !trame_ok ) // Tant qu'on est pas arrivé à "EndText 003" Fin de trame ou que la trame est incomplète
          Trame+=CaractereRecu;
    Console.println(Trame);
    // fin récupération trame téléinfo
    // envoi sur le nas les données pour insertion en base de donées
    // Initialize the client library
    HttpClient client;
    Console.println("Envoi de la requête HTTP pour stockage!");
     client.get("http://www.christellelacour.fr/teleinfo_edf/insertionData.php?trame"+Trame);
     Console.println("Traitement du retour !");
    String retourHttpGet;
     while (client.available()) {
        char c = client.read();
        retourHttpGet += c;
    retourHttpGet.trim();
    Console.println(retourHttpGet);
But now when I open the monitor I obtain this message : Connection closed by foreign host
Wha'ts going on now ...?
Elmout:
It means that you contacted a server out there somewhere on the Internet, but it didn't properly respond to your request, it just closed the connection (hung up the phone on you.) It's most likely that the server didn't like something in your request, and is actively ignoring you.
Before you make the client.get() call, I would suggest making a Console.println() of the entire string you are going to use for the request. Does it look properly formatted? Might you be missing an equal sign between the parameter name trame and the value Trame? If you manually type that exact string into your web browser's address bar, does it work or give a more meaningful error message? Does it ask you for any additional information, like a username or password?
