shift out LED / Shift in button inputs
I’m working on a pinball machine, that needs to have targets light up as triggers are switched. I’m using the (shifter.h) library for the light outputs:
http://bildr.org/2011/08/74hc595-breakout-arduino/
but I also need to use a shift register to gather a large number of button inputs. I currently don’t see any documentation on how shifter.h can call incoming data like that.
I’m wondering if I can get input data using shifter.h, and also, if I can recall that data from the same chain of shift registers I’m using to output data to the LEDs?
Here’s my code. The light turns on when I score 100. But the button doesn’t work now that I have it hooked up to the shift register. I need to change that code to talk to it:
#include "pitches.h"
#include <LiquidCrystal.h>
#include <Shifter.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define SER_Pin 7 //SER_IN
#define RCLK_Pin 6 //L_CLOCK
#define SRCLK_Pin 8 //CLOCK
#define NUM_REGISTERS 2 //how many registers are in the chain
Shifter shifter(SER_Pin, RCLK_Pin, SRCLK_Pin, NUM_REGISTERS);
  boolean lastReadButton0;
  boolean lastReadButton1;
  boolean lastReadButton2;
  boolean lastReadButton3;
  boolean lastReadButton4;
  boolean lastReadButton5;
  unsigned int score = 0;
  int ballnumber = 0;
  int a = 100;
  int b = 500;
  int c = 1000;
////NEW GAME////
int newGameMelody[] =
  NOTE_DS3, NOTE_D2, NOTE_D1, NOTE_DS3, NOTE_D2, NOTE_D1, NOTE_G4, NOTE_E4, NOTE_DS4,
int noteDurations5[] =
  8, 8, 8, 8, 8, 8, 4, 4, 2, 2,
////Ball lost melody////
int ballLostMelody[] =
  NOTE_DS3, NOTE_D3, NOTE_B2, NOTE_GS2, NOTE_B1
int noteDurations0[] =
  8, 8, 4, 2, 2,
////SCORE A////
int scoreAMelody[] =
 NOTE_E4, NOTE_E5, NOTE_E6,
int noteDurations1[] =
 8, 16, 16,
////SCORE B////
int scoreBMelody[] =
 NOTE_E7, NOTE_E6, NOTE_E5, NOTE_E4, NOTE_E5, NOTE_E6,
int noteDurations2[] =
 16, 16, 16, 8, 16, 16,
////SCORE C////
int scoreCMelody[] =
 NOTE_E7, NOTE_E6, NOTE_E5,  NOTE_E7, NOTE_E6, NOTE_E5, NOTE_E7, NOTE_E6, NOTE_E5,
int noteDurations3[] =
 16, 16, 16, 16, 16, 16, 8, 8, 8,
// SETUP===========================================
//input pins for scoring triggers
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(A3, INPUT);
  pinMode(A4, INPUT);
// set up the LCD:
  lcd.begin(16, 2);
  lcd.clear();
//LOOP==============================================
////LCD DISPLAY: SCORE / GAME OVER////
  if (ballnumber < 1)
    lcd.setCursor(0, 0);
    lcd.print("GAME OVER         ");
  lcd.print("SCORE:    BALL:");
  lcd.print(ballnumber);
//LCD: NUMERIC SCORE
  lcd.setCursor(0, 1);
  lcd.print(score);
///NEW GAME////////////////////////////////////////////////
   boolean readButton5 = digitalRead(A4);
  if (readButton5 == LOW and lastReadButton5 == HIGH)
      score = 0;
      ballnumber = 3;
      lcd.setCursor(0,1);
      lcd.print("               ");
      shifter.setAll(HIGH);
      shifter.write();
////NEW GAME MELODY////=============================
  for (int thisNote = 0; thisNote < 8; thisNote++) {
    int noteDuration5 = 1000 / noteDurations5[thisNote];
    tone(8, newGameMelody[thisNote], noteDuration5);
    int pauseBetweenNotes = noteDuration5 * 1.0;
    delay(pauseBetweenNotes);
    noTone(8);
      shifter.setAll(LOW);
      shifter.write();
 lastReadButton5 = readButton5;
///LOST BALL//////////////////////////////////////
   boolean readButton0 = digitalRead(A0);
  if (readButton0 == LOW and lastReadButton0 == HIGH)
      ballnumber = ballnumber - 1;
////BALL LOST MELODY////=============================
    int noteDuration0 = 1000 / noteDurations0[thisNote];
    tone(8, ballLostMelody[thisNote], noteDuration0);
    int pauseBetweenNotes = noteDuration0 * 1.10;
    noTone(8);
  lastReadButton0 = readButton0;
///SCORE a 100 PTS//////////////////////////////////////////////
   boolean readButton2 = digitalRead(A1);
  if (readButton2 == LOW and lastReadButton2 == HIGH)
      score = score + a;
     shifter.setPin(8, HIGH);
     shifter.write();
      ////SCORE A MELODY////=============================
    int noteDuration1 = 1000 / noteDurations1[thisNote];
    tone(8, scoreAMelody[thisNote], noteDuration1);
    int pauseBetweenNotes = noteDuration1 * 1.0;
    noTone(8);
  lastReadButton2 = readButton2;
///SCORE B 500 PTS/////////////////////////////////////////////////
   boolean readButton3 = digitalRead(A2);
  if (readButton3 == LOW and lastReadButton3 == HIGH)
      score = score + b;
////SCORE B MELODY////=============================
    int noteDuration2 = 1000 / noteDurations2[thisNote];
    tone(8, scoreBMelody[thisNote], noteDuration2);
    int pauseBetweenNotes = noteDuration2 * 1.0;
    noTone(8);
  lastReadButton3 = readButton3;
///SCORE C 1000 PTS////////////////////////////////////////////////
   boolean readButton4 = digitalRead(A3);
  if (readButton4 == LOW and lastReadButton4 == HIGH)
      score = score + c;
////SCORE C MELODY////=============================
    int noteDuration3 = 1000 / noteDurations3[thisNote];
    tone(8, scoreCMelody[thisNote], noteDuration3);
    int pauseBetweenNotes = noteDuration3 * 1.0;
    noTone(8);
  lastReadButton4 = readButton4;
and an image of my set up. I need to get the buttons bellow to light up the lights above. Can I do that on the same register chain? If not, how do I set that up so they dont override each other?
No, the 74HC595 shift register is a Serial In, Parallel Out shift register. It is not bi-directional.
You need the opposite: a Parallel In, Serial Out, such as the 74HC165, as Nick Gammon told you in your other topic.
