Shift out strange issues...
I'm having some strange issues with shiftOut.
I am seeing my clock pin giving me a 50mS pulse and the data pin staying static on my oscilloscope.
The latchpin seems to be working ok.
What I see on my output is that whatever is on the shift register gets shifted in one second intervals until the register is all high.
I should be seeing different values shifted in.
Here is my code:
int latchPin = 0;
int clockPin = 1;
int dataPin = 2;
int lifePin = 13;
int output = 100;
//Prototypes
void writeshift(byte, byte, byte);
  //set pins to output so you can control the shift register
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(lifePin, OUTPUT);
    // pause before next value:
   writeOutputs(0xff,0xff, 0xff);
   digitalWrite(lifePin, LOW);
    writeOutputs(0x00, 0x00, 0x00);
    digitalWrite(lifePin, HIGH);
void writeOutputs(byte score1, byte score2, byte outs){
    digitalWrite(latchPin, LOW);
    shiftOut(dataPin, clockPin, MSBFIRST, score1);
    shiftOut(dataPin, clockPin, MSBFIRST, score2);
    shiftOut(dataPin, clockPin, MSBFIRST, outs);
    digitalWrite(latchPin, HIGH);
    delay(1);
int latchPin = 0;
int clockPin = 1;
These pins have special meaning, with extra resistors. I'd recommend you not use them as latch and clock pins.
I actually had tested it already using 1 and 2. I know they are used to program but that shouldn't and didn't interfere with the shift register outputs. I tested it using 2 registers and it worked fine. I have an extremely high pin count usage and have my other pins occupied.
I was up until 2 AM debugging and about the 5th time I checked my wires, I realized that at one of the junctions between boards, I obviously had all of the wires crossed.
I believe that a good nights sleep is in order before doing that kind of debugging.
That implies that you do not have any / enough decoupling capacitors on the shift registers:-
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
Also there should be no capacitors on the shift register's clock or latch lines, despite what any tutorial may say.
You know Mike, I think that you are correct.
However, I definitely had an issue with crossed wires that was causing my problem.
I don't have any decoupling caps and I saw some sporadic behavior on the scope.
I haven't been able to fix my wire crossing issues yet because I have to work during the day. :frowning: but I suspect that is the primary culprit.
One of the odd things that I saw was with a volt meter, on the output QH` of the first register, when it should have been a high output, it was 8.6VDC for about a second before drifting down to 5VDC.
I have no inductance (unless it is parasitic) and no voltage above 5vdc in the system so this confuses me.
Not good.
As well as inductance you can get this effect with capacitors. If you have a capacitor in series between an output at zero and a logic input at +5V. Then when the output goes to +5V the logic input will go up to +10V before it starts to discharge. It is likely that you would see this as an 8.6V spike on a scope.
Hmm.. this is interesting Mike, I don't have any capacitors in my system besides the one ac coupling the reset pin.
Could wire capacitance do this?
I really don't see that happening off of line cap.
Everything totally worked better when I wired it correctly!
Thanks for all of the great info everybody!
Mike, you are always so fast to respond. I appreciate how much of yourself that you pour into this forum!
