Shift out Trouble!
I'm trying to use a shift register to shifout. Heres a piece of code that i worte base on my understanding of the shift out tutorial. I'm trying to set all the outputs to low except for the first 3 bits whose state i keep toggling at the end of the loop. I've connected 3 leds to these outputs to check if it works and unfortunately it doesn't seem to work. So whats wrong with my code?
my understanding is as follows
Step 1: Set Latch to Low
Step 2: Pulse the Clock Pin to High and pass 1 bit of data to the data pin - repeat step 2 eight times
step 3: pulse clock pin to low
Step 4: Set Latch pin to high
Am i right?
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
int a = 0, b = 1, c = 0;
int i = 0;
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  digitalWrite(latchPin,0);
  for(i=0; i<5; i++)
    digitalWrite(clockPin, 1);
    digitalWrite(dataPin, 0);
  digitalWrite(dataPin, c);
  digitalWrite(dataPin, b);
  digitalWrite(dataPin, a);
  digitalWrite(clockPin, 0);
  if(a ==0 && b ==1 && c==0)
    a = 1;
    b = 0;
    c = 1;
    a = 0;
    b = 1;
    c = 0;
Is there a reason why you don't use the build in shiftout function ?
http://arduino.cc/en/Reference/ShiftOut
What MikMo said...but your problem is caused by not sending the clock line low after you send it high.
Thanks guys,
Experimenting with it and its becoming clear now.
