shift register 74HC595 goes crazy on bootup
I just learned how to control many LEDs with help of chained 74HC595 swtich registers. However, on bootup of the arduino all LEDs are uncontrollable lit. Somewhere else someone mentioned that a pull down resistor would help. Is this the solution? If yes how would I integrate such a resitor?
Many thanks!
No - a pull up resistor
From the output enable pin (pin13) to +5V about 3K3. Then connect this pin to the arduino and set it low when you want the outputs to be active.
