Shift register 74HC595-switching 2LED at the same
Looking to the sample code I found in the tutorial section (http://www.arduino.cc/en/Tutorial/ShiftOut) I can switch "on" LEDs one by one using the second example. In my specific case I want to light up for example LED3 and LED7 I need to switch between LED3 and LED7 which reduces the lumen output by at least 50%, correct?
How would a code look like to have the cases as described above, so switchin on two or three LEDs the same time?
The simplest code to do just what you want, given the definitions and the setup() in the example
  // turn off the output so the pins don't light up
  // while you're shifting bits:
  digitalWrite(latchPin, LOW);
  // shift the bits out:  0B10001000 sets pins 3 and 7
  shiftOut(dataPin, clockPin, MSBFIRST, 0B10001000);
    // turn on the output so the LEDs can light up:
  digitalWrite(latchPin, HIGH);
Probably you would be wise to use a procedure to set the value:
void setBits(int val) {
  shiftOut(dataPin, clockPin, MSBFIRST, val);
and then call it like
   setBits(0B10001000);
I'll try this soon. Thanks for your help!
Sorry, too much Hex (0x) on my mind. The binary constants are B10001000, not 0B10001000.
How do you find that Led 3 and 7 = B10001000?
What's the formula?
In B10001000, bit 7 (the leftmost) bit is set, as is bit 3. The other bits are cleared.
Not neccesarily. That second example you mention, is a simple example limited to only set one output pin at a time via serial. To set more simultanously, you would have to modify the code.
You can set all 8 bits, or any combination, in a shiftregister as the posts above shows. Did you try the first example?
I tried this now and it works :smiley: :D:
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
//holder for information you're going to pass to shifting function
  //set pins to output because they are addressed in the main loop
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  shiftOut(dataPin, clockPin, MSBFIRST, B10001000);
Now my next step is to develop a code connecting single bytes from different variables to some kind of a "string of bytes" I can shift out with the sketch above. I tried to do it with the "strcat" command, but it works with char only :-[
Is there a similar command for bytes?
As long as you're not doing arithmetic on them, "byte"s are "char"s.
I do not wan to make arithmetics with them. I (think I) tried to execute what you proposed, but the result is failure message:
In function 'void loop()':
error: invalid conversion from 'char' to 'const char*/
The code I used is the following:
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
char bytestosend[50];
char first = 1;
char second = 0;
char third = 0;
char fourth = 1;
  shiftOut(dataPin, clockPin, MSBFIRST, B01000100);
   bytestosend[0] = 0;
   strcat (bytestosend, first);
   strcat (bytestosend, second);
   strcat (bytestosend, third);
   strcat (bytestosend, fourth);
   // just to check what I have done
// expecting 1001
Serial.println(bytestosend);
Take a look at the bitWrite function. It allows you to set or clear individual bits.
byte valToSend = 0;
bitWrite(valToSend, 7, 1); // Set bit 7
bitWrite(valToSend, 3, 1); // Set bit 3
valToSend now contains B10001000
Dear PaulS
That was the perfect hint! :smiley:
My system works fine with 8bit messages. I need to etent that to 24 bit but I think that isn't an issue.
Thanks to the other members of the Thread leading to that solution!
The reason this:
bytestosend[0] = 0;
failed to compile is because "strcat" expects two strings (char arrays) as arguments, whereas "first" is a simple "char" scalar.
However, it wasn't a viable solution in the first place.
