The setup:
8 buttons connected to my Arduino.
8 Leds connected to shift register (74HC595)
I want to connect button 1 to led 1, button 2 to led 2, .........
So if button 1 is pressed the led 1 should light up. But if I press button 2 when led 1 is still high, then it should only put led 2 to high.
Every example, guide or tutorial that I could find only puts 1 out of 8 leds high. I've spent hours trying to bind a button to a led, but without succes.
I have no idea how to do the following in my code:
If I press button 1:
B00000001
If I press button 2:
B00000011
If I press button 1 again:
B00000010
I hope I explained enough what my intentions are.
NOTE: I can get it to work WITHOUT a shift register. But I would like it to work using a Shift register.
NOTE2: I am not the best programmer yet
You can use bitwise XOR to toggle individual bits.
Say you've got a byte variable called LEDstate that's keeping track of the 8 LED states.
When button 1 is pressed, toggle bit 1 like this:
LEDstate ^= B00000001;
When button 2 is pressed, toggle bit 2:
LEDstate ^= B00000010;
same for button 3:
LEDstate ^= B00000100;
all the way up to button 8:
LEDstate ^= B10000000;
At suitable intervals, send the whole LEDstate byte out to the shift register. Sounds like you can do that already.
Good luck!
GypsumFantastic:
same for button 3:
Good luck!
Thanks you for your explanation. I am trying to implement bitwise XOR into my code. I picked a standard Adafruit code for the shift register, added my buttons and added the XOR. However both buttons still interact with each other. I can sometimes control Led 1 and Led 2 with Button 1. But not all the time. What am I doing wrong or forgetting here?
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
int knop1 = 1; //button 1 connected to pin 1
int knop2 = 2; //button 2 connected to pin 2
int buttonstate1 = 0; //state button 1
int buttonstate2 = 0; //state button 2
int ledaan1 = 0; //Light1 on/off
int ledaan2 = 0; //Light2 on/off
byte leds = 0;
pinMode(knop1, INPUT_PULLUP);
pinMode(knop2, INPUT_PULLUP);
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
buttonstate1 = digitalRead(knop1);
buttonstate2 = digitalRead(knop2);
if (buttonstate1 == LOW && ledaan1 == 0)
leds ^= B00000001;
bitSet(leds, 1);
updateShiftRegister();
//ledaan1 = !ledaan1;
if (buttonstate2 == LOW && ledaan2 == 0)
leds ^= B00000010;
bitSet(leds, 2);
void updateShiftRegister()
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, leds);
digitalWrite(latchPin, HIGH);
I reconnected everything on my breadboard because I wanted to make sure everything was connected properly. I noticed some pins on the shift register were bent so maybe that was the reason I got those strange results.
I also modified some code and now everything is working properly. The code is originally from here:
http://bildr.org/2011/02/74hc595/#
int SER_Pin = 4; //pin 14 on the 75HC595
int RCLK_Pin = 5; //pin 12 on the 75HC595
int SRCLK_Pin = 6; //pin 11 on the 75HC595
byte buttonState[8];
byte KnopPin[] = { 1, 3 ,2 ,7, 8, 9, 10, 11 };
//How many of the shift registers - change this
#define number_of_74hc595s 1
//do not touch
#define numOfRegisterPins number_of_74hc595s * 8
boolean registers[numOfRegisterPins];
void setup(){
pinMode(SER_Pin, OUTPUT);
pinMode(RCLK_Pin, OUTPUT);
pinMode(SRCLK_Pin, OUTPUT);
for (int x = 0; x < 2; x++){
pinMode(KnopPin[x], INPUT_PULLUP);
//reset all register pins
clearRegisters();
writeRegisters();
//set all register pins to LOW
void clearRegisters(){
for(int i = numOfRegisterPins - 1; i >= 0; i--){
registers[i] = LOW;
//Set and display registers
//Only call AFTER all values are set how you would like (slow otherwise)
void writeRegisters(){
digitalWrite(RCLK_Pin, LOW);
digitalWrite(SRCLK_Pin, LOW);
int val = registers[i];
digitalWrite(SER_Pin, val);
digitalWrite(SRCLK_Pin, HIGH);
digitalWrite(RCLK_Pin, HIGH);
//set an individual pin HIGH or LOW
void setRegisterPin(int index, int value){
registers[index] = value;
void loop(){
for (int x = 0; x < 8; x++) {
buttonState[x] = digitalRead(KnopPin[x]);
if (buttonState[x] == LOW)
setRegisterPin(x, HIGH);
writeRegisters(); //MUST BE CALLED TO DISPLAY CHANGES
else if (buttonState[x] == HIGH)
setRegisterPin(x, LOW);
writeRegisters();
//Only call once after the values are set how you need.
Excellent. Working fine how can I toggle the led with serial read.I want to use it with serial communication from another arduino like received 'A' led1 ON and received 'B' led OFF.
