shift register confusion
I have two 74HC595’s daisy chained togther - I think. All I want to do is light three LEDs on either end. The darn solution escapes me.
Any help would be appreciated.
int latchPin=11;
int clockPin=9;
int dataPin=12;
int dt=250;
byte LED1s=0B1110000000000111;
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
digitalWrite(latchPin,LOW);
shiftOut(dataPin, clockPin, MSBFIRST, LED1s);
digitalWrite(latchPin, HIGH);
tperry724:
hmmm.... using 'byte' for a 16-bit value!
also I suggest you look up the 0B notation (Integer Constants - Arduino Reference) and the datatype 'shiftOut' takes (shiftOut() - Arduino Reference)
hope that helps...
I look the long way to grandma's house but it works....
int latchPin=11;
int clockPin=9;
int dataPin=12;
int dt=500;
byte LED1A=0B00000000;
byte LED1B=0B10000000;
byte LED2A=0B00000000;
byte LED2B=0B01000000;
byte LED3A=0B00000000;
byte LED3B=0B00100000;
byte LED4A=0B00000000;
byte LED4B=0B00010000;
byte LED5A=0B00000000;
byte LED5B=0B00001000;
byte LED6A=0B00000000;
byte LED6B=0B00000100;
byte LED7A=0B00000000;
byte LED7B=0B00000010;
byte LED8A=0B00000000;
byte LED8B=0B00000001;
byte LED9A=0B10000000;
byte LED9B=0B00000000;
byte LED10A=0B01000000;
byte LED10B=0B00000000;
byte LED11A=0B00100000;
byte LED11B=0B00000000;
byte LED12A=0B00010000;
byte LED12B=0B00000000;
byte LED13A=0B00001000;
byte LED13B=0B00000000;
byte LED14A=0B00000100;
byte LED14B=0B00000000;
byte LED15A=0B00000010;
byte LED15B=0B00000000;
byte LED16A=0B00000001;
byte LED16B=0B00000000;
shiftOut(dataPin, clockPin, LSBFIRST, LED1A);
shiftOut(dataPin, clockPin, LSBFIRST, LED1B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED2A);
shiftOut(dataPin, clockPin, LSBFIRST, LED2B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED3A);
shiftOut(dataPin, clockPin, LSBFIRST, LED3B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED4A);
shiftOut(dataPin, clockPin, LSBFIRST, LED4B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED5A);
shiftOut(dataPin, clockPin, LSBFIRST, LED5B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED6A);
shiftOut(dataPin, clockPin, LSBFIRST, LED6B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED7A);
shiftOut(dataPin, clockPin, LSBFIRST, LED7B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED8A);
shiftOut(dataPin, clockPin, LSBFIRST, LED8B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED9A);
shiftOut(dataPin, clockPin, LSBFIRST, LED9B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED10A);
shiftOut(dataPin, clockPin, LSBFIRST, LED10B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED11A);
shiftOut(dataPin, clockPin, LSBFIRST, LED11B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED12A);
shiftOut(dataPin, clockPin, LSBFIRST, LED12B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED13A);
shiftOut(dataPin, clockPin, LSBFIRST, LED13B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED14A);
shiftOut(dataPin, clockPin, LSBFIRST, LED14B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED15A);
shiftOut(dataPin, clockPin, LSBFIRST, LED15B);
delay (dt);
shiftOut(dataPin, clockPin, LSBFIRST, LED16A);
shiftOut(dataPin, clockPin, LSBFIRST, LED16B);
delay (dt);
Thank you for the help.
Tony
Sure did. LEDxA, LEDxB could have gone into an array, then used a for loop to sequence thru the array.
Would have made loop() quite a bit shorter.
The array would still be needed. Easier to see what's going on vs trying to manipulate all the data back & forth.
CrossRoads,
Don’t suppose you could point me in the right direction with a snippet of code and an explanation as to how it works? I’m learning but still a newbie.
Best,
Tony
