Hey:
Im using four 74HC595 in parallel. I am shifting out using a modified shiftOut function. My query is about how consistent the registers latch is.
For some reason my whenever the latch is set to HIGH the last pin at least is going HIGH for a split second even though I have not told it to. (I only tell it to be HIGH at the very end before it loops)
I have included the example app along with my ‘Shifter’ library.
Any help greatly appreciated…
DigitalJohn
Example App:
#include <SPI.h>
#include <Shifter.h>
Shifter shift(3,6,5,5);
shift.clear();
// start the serial library:
shift.clear();
delay(10000);
shift.swipeFromTo(0, 36, 250);
shift.clear();
delay(3000);
shift.set(39, true);
shift.apply();
Shifter Library
#include "WProgram.h"
#include "Shifter.h"
Shifter::Shifter(int latchPin, int clockPin, int dataPin, int registers)
_latchPin = latchPin;
_clockPin = clockPin;
_dataPin = dataPin;
_registers = registers;
pinMode(_latchPin, OUTPUT);
pinMode(_clockPin, OUTPUT);
pinMode(_dataPin, OUTPUT);
clear();
void Shifter::clear()
for (int i = 0; i < (_registers*8); i++)
_data[i] = false;
apply();
void Shifter::swipe(int pause)
if(i > 0) _data[i-1] = false;
_data[i] = true;
apply();
delay(pause);
clear();
void Shifter::swipeFromTo(int from, int to, int pause)
for (int i = from; i < to; i++)
_data[i] = true;
apply();
delay(pause);
clear();
void Shifter::swipeBack(int pause)
for (int i = (_registers*8); i >= 0; i--)
if(i < (_registers*8)) _data[i+1] = false;
_data[i] = true;
apply();
delay(pause);
clear();
void Shifter::apply()
digitalWrite(_latchPin, LOW);
for (int i = 0; i < _registers*8; i++) {
digitalWrite(_dataPin, _data[i]);
digitalWrite(_clockPin, HIGH);
digitalWrite(_clockPin, LOW);
digitalWrite(_latchPin, HIGH);
void Shifter::set(int position, bool value)
_data[position] = value;
void Shifter::pulse(int position, int duration)
_data[i] = false;
set(position, true);
apply();
delay(duration);
clear();
