Shift Register only works when hand is close
Connect all ground pins to ground.
There is also G pin (pin 9) that should also be grounded for the outputs to output.
When output enable (G) is held high, all data in the output buffers is held low and all drain outputs are off.
When G is held low, data from the storage register is transparent to the output buffers.
Docedison:
From the symptoms you quote you have a 'floating' input to the S.R.
Sorry, what is the S.R.?
As for the drawings and exact code - I will post these as soon as I get home after work with the remaining issues that I have.
As promised, here is my wiring diagram and the exact code I am using. The Arduino that I am using is actually an Arduino Micro but I couldn't find that in the Fritzing program. All pins are correct though.
Right now, the shift registers are working properly, yay! I have not gotten any interference since I changed the wires to proper jumper wires.
The problem though that I am having now is that my transistor is not working. If I screw around and plug things in and hold some wires, it will sometimes work. The transistor datasheet is here: https://www1.elfa.se/data1/wwwroot/assets/datasheets/cgON-BC546-548_en.pdf
My exact code is as follows:
//Pin to clear the register
const int clearPin = 7;
const int latchPin = 8;
const int clockPin = 12;
const int dataPin = 11;
int i = 0;
  //set pins to output because they are addressed in the main loop
  pinMode(clearPin, OUTPUT);
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  Serial.println("*");
  // delay a little and then set
  delay(100);
  // Always start by sentting SRCLR high
  digitalWrite( clearPin, HIGH);
  // write to the shift register with the correct bit set high:
  if (i == 2) {
    i = 0;
  registerWrite();
  i++;
// This method sends bits to the shift register:
void registerWrite() {
  // the bits you want to send
  byte bitsToSend0 = 0;
  byte bitsToSend1 = 0;
  // write number as bits
  bitWrite(bitsToSend0, i, HIGH);
  bitWrite(bitsToSend1, i, HIGH);
  // turn off the output so the pins don't light up
  // while you're shifting bits:
  digitalWrite(latchPin, LOW);
  // shift the bits out
  shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend1);
  shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend0);
  // turn on the output so the LEDs can light up:
  digitalWrite(latchPin, HIGH);
transistor.fzz (10.8 KB)
From what I can make out from that tangled mess, you have your transistor wired up like:
That is wrong. Firstly your current limit resistor is in the wrong place (it is offsetting the transistor, which is bad), plus you don't have a current limit resistor on the base, which is bad, as it could kill your shift register.
It should be like this:
I am not sure exactly how to read those diagrams but I gave it a shot. Alas, it doesn't work.
Attached is how i have wired up the LED with the transistor. Right now I only get some current through the LED when I am holding wire 2 between my fingers - but not much as the LED only lights up a little.
Am I doing this wrong?
That looks right, and the fact that touching wire 2 turns it on (probably flickering at 50/60Hz) means it's wired fine. It sounds like the output you are connecting it to though isn't actually running as an output, and the connection is floating.
majenko:
Ok, but how could that be? If I take the transistor out and just have the LED connected like: 5V - resistor - LED - shift register pin - it all works just fine. I can I get it to work properly?
Datasheet:
Outputs are low-side, open-drain DMOS transistors with output ratings of 50 V and 150-mA continuous sink-
current capability.
Add a 10K pull-up resistor between the shift register output and +5V.
Note that the output operation (HIGH/LOW) will be reversed.
majenko:
So I should put this pull-up resistor connecting wire 2 and 3?
Yes. The "outputs" of the shift register act just like your transistor - they are "off" so then are high impedance (open circuit), or "on" and connected to ground. You need power from the 5V rail to turn your transistor on, and when you turn on the output to the shift register it connects the base of your transistor to ground, turning it off.
majenko:
Wouldn't this just connect the collector to the base of the transistor? How would this allow the power to flow to the emitter in of the transistor?
You put electrickery into the base of the transistor and it turns on. The resistor to +5V provides said electrickery.
You turn on the output of the shift register and it connects that resistor to ground, giving a lower resistance path for the electrickery to go though, so less goes into the base, turning the transistor off.
Think of the output of the shift register like a button. When on it connects the output pin to ground.
Excellent, I understand! And, I have gotten it to work properly!
The last question I have though is - do I really need so many wires? It really seams like I have way more wires than nessicary. For example, this tutorial has only a few wires for each shift register and doesn't have the extra cross between the base and collector of the transistor. Is it just the parts that I bought that make this more complex?
Most shift registers (like the 74xx595) use TTL (or similar) outputs, which output a positive voltage when turned on. This makes connecting transistors and similar much similar. However, they generally can't provide much current. The shift register you have effectively has the transistor you have wired up inside the chip, so it can "sink" (which is what your transistor is doing) more current - something like 150mA per output (check the data sheet for exact figures). So, if you're not wanting to connect anything that uses more than 150mA then you don't need any of your external transistor, but can just use the shift register directly. The output of the shift register would be the collector of the transistor. So, to use it like a 74xx595 is slightly more complex, but to use it "properly" can be simpler, depending on your application.
Ok, so most registers actually output current while mine "sink"s the current (inputs the current per-say). Is this correct?
I am using this all to control an LED array. I am using the registers to control 25 columns and 15 rows. The plan is to sink 1 row at a time and make the columns provide the power so that each LED has it's own power supply, giving maximum brightness. I am using the transistors to switch on-off the power to the columns, thus giving total control.
Maybe it makes more sense to get simpler output-current registers for the columns while using the sink-current registers for the rows? This would make the transistors easier to use (if I would even still need them, depends on how many LEDs I am trying to power I suppose). Is this a correct thought process?
shiznatix:
Yep, that is correct. Use something like a 74HC595 to power the LEDs, and use your existing shift register to sink the groupings (columns, rows, whatever).
If you are going to have lots of LEDs connected from one output of the 595 and have them illuminated at the same time then you will need a transistor, but as it's a "high side" switch, make it a PNP, not an NPN.
majenko:
Why would I use a PNP WITH THE 595? Since the 595 would push the current, wouldn't I use a NPN transistor to control 5V flowing to each column (while using my current shift registers to sink the rows when needed)?
Basically, couldn't I use the 595 ouput pins as the switch on the NPN transistor to unleash the 5V when the register pin is turned HIGH?
shiznatix:
majenko:
The rule is, if you are switching the connection between a load (led, relay, etc) and ground, then you use an NPN. If you are switching the connection between the power (+5V, +12V, etc) and a load, then you use a PNP.
shiznatix:
I am trying to learn to use the TPIC6B595N shift register http://www.adafruit.com/datasheets/tpic6b595.pdf but I am having a strange problem. The register only works every now and then and very often it works only when my hand is nearby.
I just ran into this problem yesterday with one of these. I got in a hurry and didn't connect the SRCLR pin - it was floating. I could control the chip by hand movements, just like Darth Vader. A floating pin can really mess with your mind!
