Hello,
i am currently playing around with a dual shift register set up on a bread board and a simple code that turns 16 LEDs on and off in sequence from eachother. Now, since the outputs are at 5v each i can use it to trigger an envelope generator on this little modular synth that i have, but the only problem is that the pulses going out are full until the next LED is triggered, which means there's no release time in between a shift thus the envelope generator stays "gated". Is there any way i can easily make them into shorter pulses?
