shift registers and rgb leds
im using this code. and its supposed to scroll the leds but my scroll is retarded.
it seems the on leds are off and the off leds are on. how do i fix this?
int DS_pin = 11;
int STCP_pin = 8;
int SHCP_pin = 12;
pinMode(DS_pin,OUTPUT);
pinMode(STCP_pin,OUTPUT);
pinMode(SHCP_pin,OUTPUT);
writereg();
boolean registers[8];
void writereg()
digitalWrite(STCP_pin, LOW);
for (int i = 7; i>=0; i--)
digitalWrite(SHCP_pin, LOW);
digitalWrite(DS_pin, registers[i] );
digitalWrite(SHCP_pin, HIGH);
digitalWrite(STCP_pin, HIGH);
for(int i = 0; i<8; i++)
  registers[i] = HIGH;
  delay(100);
  writereg();
  for(int i = 7; i>0; i--)
  registers[i] = LOW;
  delay(100);
  writereg();
Please read:- How to use this forum It will tell you that posting code without a schematic is a bit useless, although it uses more contrite words.
Do you mean retarded in the correct sense of the word as backwards, or in the slang sense of the word as not functional as you require?
