Arduino Project
Hello, I have in my mind a project like below.
1 Connect the arduino with 6 LED's controlled with a Shift register
2 Read from a text file the light sequence and put into the register (1,2,4,8,16,32,16,8,4,2)
So this would light each LED in sequence like the KITT sweep example.
3 Connect a timer to the project which would control when to perform the next LED lighting event from reading another text file, example 1,0,1,0,1,0
4 So if the clock was set to 60 BPM, the first value is "1" so light up the first LED. The next value on the clock is "0" so do nothing ,the next is "1" so light up the second LED etc etc.
so after the circuit is working correctly I could change the light sequence and the timer sequence to whatever I want, ie Light sequence (1,2,4,16,8,32,16,8,16,2) and the timer to (1,0,0,1,1,0,1)
Does this make sense
Any pointers here?
Regards
Geoff
