Shift registers
Hi my project is based on http://www.arduino.cc/en/Tutorial/ShiftOut and Overview | Arduino Lesson 4. Eight LEDs and a Shift Register | Adafruit Learning System.
What I have is the board set up like in the Shift Out tutorial just with 7 led's per shift register instead of 8 that is shown in the tutorial.
As for code what I have for now is:
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
byte leds = 0;
int firstSet = 1;
int secondSet = 2;
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  leds = 0;
//For first set of (red) leds / first shift register
if(firstSet==1)
disleds0();
else if(firstSet==2)
  disleds1();
else if(firstSet==3)
  disleds2();
//For second set of (green) leds / second shift register
if(secondSet==1)
disleds0SS();
else if(secondSet==2)
  disleds1SS();
else if(secondSet==3)
  disleds2SS();
void updateShiftRegister()
   digitalWrite(latchPin, LOW);
   shiftOut(dataPin, clockPin, LSBFIRST, leds);
   digitalWrite(latchPin, HIGH);
void disleds0()
  bitSet(leds, 0);  //if firstSet == 1 light up the first led
    updateShiftRegister();
void disleds1()
  bitSet(leds, 1); //if firstSet == 2 light up the second led
void disleds2()
  bitSet(leds, 2); //if firstSet == 3 light up the third led
void disleds0SS()
  bitSet(leds, 0); //if secondSet == 1 light up the first led on the second shift register
void disleds1SS()
  bitSet(leds, 1); //if secondSet == 2 light up the second led on the second shift register
void disleds2SS()
  bitSet(leds, 2); //if secondSet == 3 light up the third led on the second shift register
(I left out some of the repeating code to make the code easier to read.)
So the problem is that when I run the code with firstSet = 1 and secondSet = 2 the first two led's for both sets of led's are lighting up when in this case I would only want the first led to light on the first set of led's / shift register and for only the second led on the second set of led's / second shift register.
In more straight forward way how do I send specific data to each shift register.
(as far as I know i have to send a second shift out, I think, I just don't know how to do it. )
Thanks in advance.
  1. Get rid of the cap.
  2. Put a 0.1uF cap from each device's Vcc pin to Gnd.
  3. Fix your code to output 2 bytes every time you want the output updated.
   shiftOut(dataPin, clockPin, LSBFIRST, leds1);
   shiftOut(dataPin, clockPin, LSBFIRST, leds2);
and keep the data you are sending out in leds1 and leds2
Thanks a lot I still have to test all the details but as far as I can tell this is working as planed.
Thank you so much.
