Shift Voltage Range for Analog Read Range
Hi all,
The project I am working involves reading a voltage that can be in the range of -2 to 3V, on the Analog Port, which can only pick up voltages ranging from 0-5V. Colleagues of mine have suggested using a diode clamp, op amp, or a Voltage divider. I was hoping someone could give me a suggestions on which set up would work best for my application, as well as where I can look for exact specs for accomplishing this.
Thanks!
Bias resistors.
Have a read of this www.ti.com/lit/an/sloa097/sloa097.pdf
@Riva could expand more, what type of circuit would I use those in for my appliaction?
@Grumpy_Mike thanks for providing the link. Would you suggest using either 3.3V or 5V directly from the Arduino for Vref?
You can but you will need to power your op amp with voltages that are greater than the range of voltages seen by the input.
Ah I see, thanks!
